17" OEM TRD Wheels on 6" Pro Comp Lift?
Discussion in 'Wheels & Tires' started by Smoken_Bud_671, May 6, 2010.
  1. May 6, 2010 at 4:53 AM
    Smoken_Bud_671
    Smoken_Bud_671 [OP] Well-Known Member
    GU 671
    Shining Beast
    Flowmaster exhuast K&N Intake Filter
    Hey guys... I don't know if this has been discussed here on other posts.
    I tried searching briefly and I did not find any discussions on this.
    Maybe someone sporting a 6" Pro Comp lift can shed some light on this.
    Will 1.25 spacers suffice to run the factory 17" TRD wheels on this lift?
    Will the backspacing improve to give ample room for the wheel once these spacers are installed?
    As I know without the proper backspace the tie rods will hit the wheel.
  2. May 6, 2010 at 4:49 PM
    Smoken_Bud_671
    GU 671
    Shining Beast
    Bumping to the top...
    I'm hoping someone can chime in on this, as I would like to use the factory TRD wheels every now and then.
    Thanks in advance to everyone who can shed any light on this. :)
  3. May 7, 2010 at 8:47 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    What size tires are you planning on running?
  4. May 8, 2010 at 5:01 PM
    Smoken_Bud_671
    GU 671
    Shining Beast
    Tire size (factory) - 265/65
  5. May 8, 2010 at 5:14 PM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    You're going to add a six inch lift but run factory tires??
  6. May 9, 2010 at 4:02 AM
    Smoken_Bud_671
    GU 671
    Shining Beast
    6" lift is already on there (see my sig) I would like to run the stocks for a couple of weeks to get my aftermarket wheels really cleaned up.
  7. May 9, 2010 at 1:16 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Do you have Mickey Thompsons?
  8. May 10, 2010 at 7:17 AM
    sirsaechao
    Tim
    Commifornia
    His link says 35" ProComp Xtreme A/T's.
    OP: What did you do with your 17" Moto Metals and 35's? Did you sell those? Or traded those for stock wheels and tires until you get your new set? Is that why you are asking about stock wheels and tires on 6" lift?
  9. May 13, 2010 at 3:16 AM
    Smoken_Bud_671
    GU 671
    Shining Beast
    I still have the 17" Moto's wrapped in 35's and the Taco is still rolling on these, but I would like to roll on the stock OEM TRD wheels for a few weeks.
    Just would like to get the Moto's really cleaned up & put them back on.
    Would you or anyone know if I would also be able to use the hub centric spacers when running the Moto's?
    I ask this because the Moto wheels are not hub centric. My take on this is... I should not have any problems as I have been using these wheels and they are not hub centric. I have been using them on the Taco for almost a year already and the Taco is hub centric.
    Thanks!
  10. Jun 3, 2010 at 11:56 PM
    Smoken_Bud_671
    GU 671
    Shining Beast
    Any ideas or comments on this is appreciated? Thanks!
  11. Jun 4, 2010 at 12:01 AM
    Snowman20
    Snowman20 Active Member
    Cody
    Vancouver
    07 Trd Off-Road 4x4
    ya, sure, take an afternoon on the weekend and buff your wheels ;)
