17 Pro Lift Questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gr8fl, Jan 28, 2018.
  1. Jan 28, 2018 at 2:49 PM
    Gr8fl
    Gr8fl [OP] Some rise, some fall, some climb.
    JK
    Central Bucks, PA
    17 Cement Pro, 20 MGM Land Cruiser
    Experts laugh as needed, looking for advice and help here.
    My goals: 2017 stock Pro. (1) I’d like to swap my 16” wheels for 17” after market (like the Pro Comp Series 40 or the Method NVs), (2) I have E rated KO2s 265/70 and I’d like to go to C rated tires to lower unsprung weigh and go 1 to 2 inches bigger to 275 or 285 - or alternatively - pizza cutter range - and (3) lift the truck 1 inch. I’m trying to keep overall height increase around 2.5 inches to stay within certain parking garage ranges - the airport. The lift would be to clear the tires without rubbing.
    I’m likely under and over thinking this because Im not a suspension expert, but (1) can I keep the stock suspension and go 1” higher, or do I need a complete swap (no spacers wanted) (2) for the new wheels thinking pizza cutters, or staying relatively narrow, negatives to this? (3) any other advice, any is welcome.
  2. Jan 28, 2018 at 2:53 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    275s stock no problem, pizza cutters stock is doable. Lift will be a swap out. 285s, lift cmc/trimming(if not pizza cutters) alot depends on backspacing and offset.
    ps read until you cant read anymore.... c-rated why not go lt or p, falken wildpeaks
    Gr8fl[OP] likes this.
  3. Jan 28, 2018 at 2:56 PM
    Gr8fl
    JK
    Central Bucks, PA
    I’m absolutely not an expert on backspacing and offset, any advice on how to think about this? Thanks for the advice.
  4. Jan 28, 2018 at 2:59 PM
    Clearwater Bill
    Billy
    Largo Florida
  5. Jan 28, 2018 at 3:06 PM
    Gr8fl
    JK
    Central Bucks, PA
