17" rims on 265/70 or 265/75 with stock suspension?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Frankie_the_taco, Oct 23, 2020.
  1. Oct 23, 2020 at 8:44 PM
    Frankie_the_taco
    Frankie_the_taco [OP] Member
    my 1st gen tacoma has stock suspension with no lift/level kit. its stock tire is 265/70/R16 and from what i understand, the highest i can go without any modifications is 265/75. so i was wondering if i can fit a 17 inch rim on the 265/70 tire size or the 265/75 tire size without any issues. i would prefer to keep the stock height and suspension and avoid trimming but if i have to get a lift/level kit in order to use the 17 inch rim, then what size level/lift kit would i need?
  2. Oct 23, 2020 at 8:49 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    265/75/16 is same as 265/70/17
  3. Oct 23, 2020 at 9:06 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    A 265/70-17 will fit fine. Same as a 265/75-16
    Wulf and turbodb like this.
  4. Oct 24, 2020 at 7:42 AM
    Frankie_the_taco
    Is there rubbing with those size options?
    And is it possible to do a 265/75/17 without rubbing, trimming or any modifications to the suspensions?
  5. Oct 24, 2020 at 8:59 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Welcome to TW!
    I agree with Daniel - you'll be just fine with 265/70-17, assuming you get wheels that have essentially the same width and backspacing as stock wheels. That means you're looking for something with ~4-4.5" of backspacing.
    More backspacing than that (5, 5.5") and you'll find yourself rubbing the frame. Less (3.5") and you could end up rubbing the outer rear fender flare a bit.
    Here's a good overview of what comes into play with various wheel/tire combos on a 1st gen. Take a read through and by all means ask questions!
    What size tires fit my (lifted) Tacoma?
    phx70 likes this.
  6. Oct 24, 2020 at 10:18 AM
    SierraMare
    SierraMare Well-Known Member
    Ted
    Alaska
    2001 TRD OffRoad Xtracab, stepside bed, 2.7 L, 5-speed manual
    ARE cap, BFG KO2 (LT 245/75R16), Front Bilstein 5100 with OME 2881 coils, Rear HS 3-leaf progressive AAL.
    i just recently put a smaller tire on a 17” 4Runner rim -fit fine. I have a neighbor with a first gen standard cab, also with 17” 4Runner rims with 245/75R17 tires (31”) - looks great. 4Runner/FJ Cruiser rims have the right back spacing for our first gen Tacoma’s.
    Hamer95USA likes this.
  7. Oct 26, 2020 at 7:34 PM
    Frankie_the_taco
    so the rims that i found are 17x9" and they come with 2 options of offset. -12mm and 12mm. i would prefer the flush look on my truck, but knowing that i have to take into consideration the backspacing, which of those offsets will get me that flush look and wont give me any type of rubbing??
    note* im gonna be putting 265/70 tires on the rims
  8. Oct 26, 2020 at 9:48 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    That's a pretty wide wheel. This tool is a good one for you: > The calculator is on the left, and you have to click on the "Offset Converter" tab.
    When you do that, you'll see that with a 9" wheel, a 12mm offset is equal to a 5.47" backspace. A -12mm offset is 4.53" backspace.
    So, -12mm offset will mean that the wheel has about the stock amount of backspace (and so will not rub on the suspension components - UCA, spindle, etc. - and frame). However, since it's 2" wider than a stock wheel, it will protrude 2" further from the wheel well - so you won't get the "flush" look.
    A 12mm offset will move the wheel toward the frame by nearly an inch. While this will give you a more flush look, you may rub the suspension, frame, etc. It might be that you have to run a spacer to push it back out - thus making it more like the -12mm offset version of the wheel.
    Personally, I'd try to find another wheel. One that is 8" wide. I think you'll be happier in the long run if you want a "flush" look. SCS wheels come in 8" variants, if you like any of those.
    SierraMare likes this.
