17" stock - 265/70/17 - 1.25" spidertrax combo?
Discussion in 'Wheels & Tires' started by jermoids, Dec 9, 2012.
  1. Dec 9, 2012 at 10:53 AM
    jermoids
    jermoids [OP] Well-Known Member
    Jeremy
    Winnipeg, Manitoba, Canada
    2021 TRD Sport
    17x9 Fuel Mavericks +1 offset 265/65/17 duratracs NFAB Epyx step sides AVS hood protector Thule xsporter pro rack Weathertech floor liners Tacoma rubber bed mat
    is anyone on here running 17" stock rims with 265/70/17 tires along with 1.25" spidertrax spacers?
    i want to get some spidertrax spacers but i don't want to have to cut/trim or remove anything.
    was wondering if anyone is running this combo and if they have had any issues with it.
    thanks.
    again, i know there are a ton of threads about this but it's hard to find the exact answer you want filtering through 5000 posts.
  2. Dec 9, 2012 at 11:48 AM
    gthupman
    gthupman Well-Known Member
    Greg
    Raleigh, North Carolina
    '17 DCSB Super White Offroad
    sub'd
  3. Dec 10, 2012 at 7:54 AM
    jermoids
    Jeremy
    2021 TRD Sport
    bump it up, anyone? rubbing issues? no issues? i need my mud flaps for where i live and i don't want to cut anything.
  4. Dec 10, 2012 at 8:03 AM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    i'm running 265/70R7 goodyear duratracs on kmc wheel swith 4.5in of backspacing unleveled or lifted and i have rubbing issues. had to cut some of the plastic liner in front of the wheels and finally decided to remove the mudflaps b/c they were rubbing there too. i tried shaving them and cutting off as much material as possible yet keep them attached to the truck with no luck.
    hope this helps a little
  5. Dec 10, 2012 at 8:10 AM
    jermoids
    Jeremy
    2021 TRD Sport
    hey thanks, im thinking i will have rubbing issues, i was just hoping that still being on the stock wheels might help, hopefully someone on here is running them and can chime in. i have pm'd a couple people, seems 50/50 on having issues or not though.
    i've got 5100's set at 1.75" as well if that makes much difference?
  6. Dec 10, 2012 at 12:12 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    I was running this exact combo for several months until recently, when I went to aftermarket wheels and sold the spacers. Even with my 5100's at 1.75, I rubbed on the mudflaps with the spacers on.
  7. Dec 10, 2012 at 12:13 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Why would you want spacers if the wheels/tires will fit perfectly fine as-is?? :confused:
  8. Dec 10, 2012 at 12:25 PM
    jermoids
    Jeremy
    2021 TRD Sport
    good to know, thanks!
    just looking for a bit of wider stance/look.
  9. Jun 1, 2013 at 10:57 AM
    StreetTaco4Me
    StreetTaco4Me Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    did you trim or just let it rub...when would it rub and how bad was it?
    I also just want a wider stance...am also going to have 5100 set to 1.75 front and 1.5 Icon progressive aal in rear
    I like the stance and do not want to trim
