'17 Tacoma - Misfire Cylinder 5, System Too Rich Bank 1 (HELP)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tannerowens3, Sep 26, 2022.
  1. Sep 26, 2022 at 2:42 PM
    tannerowens3
    tannerowens3 [OP] Member
    Truck started bogging down at stop light. Trac & Engine light came on. Detected cylinder misfires on 1,3,5. Changed spark plugs and got only a misfire on cylinder 5. Cylinder 5 plug was wet with fuel. After that I took it to the dealer where they inspected wires, coils. They performed a leak down test on cylinders 3 (174 psi) & cylinder 5 (170 psi). They told me it was the fuel injectors, so when they went to swap injectors, they noticed cylinder 5 had an intake valve leak. They wanted to charge me around $7,000 to send to machine shop to get fixed. I took my vehicle and ran. Is this a fishy diagnosis? And does anybody have other ideas on what it could possibly be? Thanks.
  2. Sep 26, 2022 at 2:46 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Likely not fishy, but they were certainly throwing parts at it.
    Unfortunately, a few Tacos have had valve seat issues in Cylinder 5. It should be fixed if still in the powertrain warranty, but I would think that you are past that now.
  3. Sep 26, 2022 at 2:49 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    How many miles?
  4. Sep 26, 2022 at 2:50 PM
    tannerowens3
    69k miles
  5. Sep 26, 2022 at 3:03 PM
    eurowner
    eurowner Duke Sky
    Scoty
    What year and build date?
  6. Sep 26, 2022 at 3:10 PM
    tannerowens3
    2017. October 2017
    eurowner[QUOTED] likes this.
  7. Sep 26, 2022 at 5:15 PM
    Clipper16
    Clipper16 Well-Known Member
    Gil
    Tennessee
    2018 TRD Sport ACLB Intense White Tech and Pro
    Intake valve leak should have shown up on the leak down test.
    That test is done with piston at TDC on the power stroke and all the valves closed
  8. Sep 26, 2022 at 5:26 PM
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    And 170 psi of compression ? It's one or the other. If it leaks down after 20 minutes, big whoop. it only needs to hold pressure for a few ms.
    Run a couple of cans of Seafoam or techron ect. Maybe there's a bit of carbon on the valve seat.
  9. Jan 3, 2023 at 11:39 AM
    tannerowens3
    Update: Took it to a hometown mechanic and it ended up being the direct fuel injectors (internal) on bank 1.
    No intake valve leak.
    eurowner and mattleg like this.
  10. Jan 3, 2023 at 11:41 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    What percentage leakdown does it have?..we see some direct injections with carbon under the valves
