17" TRD Pro rims and BFG AT TKO2s...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BMunster, Apr 12, 2016.
  1. May 31, 2016 at 5:07 AM
    #181
    el_zorro1
    el_zorro1 Well-Known Member
    Zorro
    Northern Virginia
    I decided to keep the factory spare tire and wheel...as it will be for temporary use in the event of a flat.
  2. May 31, 2016 at 5:13 AM
    #182
    WrecK
    WrecK Well-Known Member
    Rat City, WA
    2016 Black Tacoma TRD Sport DCLB
    Are we ever done? Haha
    209tacoma likes this.
  3. May 31, 2016 at 5:28 AM
    #183
    WrecK
    Rat City, WA
    It should fit fine, but depending on tire size it could require a mod. I don't think it's uncommon. I'm deciding between a bed mount or a mount that swings out at the rear bumper.
    Found this thread, it has some good info
    https://www.tacomaworld.com/threads/full-size-spare-mounting-options.377916/
  4. May 31, 2016 at 7:35 AM
    #184
    Tedward
    Tedward Well-Known Member
    DMV/N. VA
    2016 DCSB TRD Sport 4x4
    Too many to list...
    No shuddering or vibration issues with mine... have the c-rated 265/70/17 ko2s. Had them on stock sport wheels and now the trd pros. both perfectly smooth.
    pescadoman66 and BrettsMac08 like this.
  5. May 31, 2016 at 8:39 AM
    #185
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    it seems not but I'm hoping this is it for me. The only think left would be a lift and with not
    going off road and my ride never being the same after I lift, I said screw it this time. I'm already
    in it for almost 4k in after market parts and it's not even a year old! :D
    WrecK[QUOTED] and BrettsMac08 like this.
  6. May 31, 2016 at 9:43 AM
    #186
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    Sounds familiar! I don't do enough wheeling to warrant any lift. Just back roads and the tires are more than enough for that. It just looks cool. Lol. I did a mild lift on my Tundra to make up for the Ranch Hand I put on it so it didn't bang on the ground. But that was it.
    Between the exhaust, sound system, wheels, tires, and tonneau cover I think I sunk 5K in it in 6 months. I'm doing a self-imposed intervention for my own well being. Nothing else on my list though so I should be good.
    Hoping for at least 5 years if not 10 from her depending where life leads me. Should fit car seats if/when needed and that's a long ways down the road for me.
    Sitting at discount tire getting them balanced once again. This time the manager is going to do it. So hopefully it gets done right this time or they find a bad tire.
  7. May 31, 2016 at 9:46 AM
    #187
    BlkTaco47
    BlkTaco47 Unhinged
    Nice!
    Balanced again? You're running the thread title setup?
  8. May 31, 2016 at 10:07 AM
    #188
    BrettsMac08
    Kansas
    Yup. 17" TRD Pro 4Runner wheels (actually saw them on a TRD Pro 4Runner yesterday going though a drive thru) and 265-70-17 BFG AT TA KO2s. They found that 3 out of 4 tires weren't quite straight. And 1 will probably need to be replaced. The other two they are trying to straighten out and road force balance using the Toyota adapter plate too. Should get me fixed up.
  9. May 31, 2016 at 10:09 AM
    #189
    BlkTaco47
    BlkTaco47 Unhinged
    damn! We'll have the same setup... Hoping for better on mine that are due in Thurs.
    How can they "try and straighten" it? Wouldn't be easier/better getting it replaced?
  10. May 31, 2016 at 10:20 AM
    #190
    BrettsMac08
    Kansas
    Just kidding. Ends up they realized that they put the E rated (10 ply) tires on instead of the 6 ply load C tires. Derp. I didn't even think to check that but it did feel a bit stiffer than I thought. Considering I was able to get 18.7 MPG average on my last tank with E rated tires doesn't seem that bad!
    So I will be getting all new tires after all! Let's just hope these are all manufactured properly and can be balanced right this time. Lucky for me I have the day off due to memorial day with our office closed on Monday. First two day weekend I've had in months!
    Best of luck to you though. It seems like most have been fine, I just have some bad luck. Runs in the family :rofl:
    I'll update later with how it goes. Fingers crossed it all works out the first time this time.
  11. May 31, 2016 at 11:04 AM
    #191
    BlkTaco47
    BlkTaco47 Unhinged
    oh ok! just the tires were out of wack. Mine have been on the stock wheels running perfect
    for the last 2k miles so I should be good.
  12. May 31, 2016 at 11:21 AM
    #192
    stolenword
    stolenword Active Member
    Quick question, what psi is everyone running at?
  13. May 31, 2016 at 11:22 AM
    #193
    BlkTaco47
    BlkTaco47 Unhinged
    36 all around for me
  14. May 31, 2016 at 11:23 AM
    #194
    stolenword
    Thanks for the quick response. I am running 34 but I also live in south Florida. What mpg are you averaging?
  15. May 31, 2016 at 11:24 AM
    #195
    BlkTaco47
    BlkTaco47 Unhinged
    sure man.
    19-23 is the avg. I'm at 5200 miles now with lots of stop-n-go highway
    travel and about 40% city, so not bad at all.
  16. May 31, 2016 at 11:26 AM
    #196
    stolenword
    Awesome, I am at 7900 miles and have been averaging 21-22 on commute with mostly city. I haven't tested with new tires yet since working from home today. Do you think 34 cold is decent, they should get up to 37 hot in florida?
  17. May 31, 2016 at 11:29 AM
    #197
    BlkTaco47
    BlkTaco47 Unhinged
    mine usually go to 32/33 when it's cold here in Va. and then back up
    to around 36/37 as it heats up outside.
  18. May 31, 2016 at 5:29 PM
    #198
    Narly 45
    Narly 45 New Member
    IMHO, perfect set up! Thanks for sharing!
  19. May 31, 2016 at 6:50 PM
    #199
    SLACKBOY
    SLACKBOY Toyota For Life!
    Erich
    Washington State
    2016 MGM Toyota Tacoma OR 4x4
    Blacked Out Emblems Wet Okole Seat Covers Installed Tinted Front Windows Weathertech Digital Floor Liners for the Front Plasti Dipped OF Grill - Removed BAMF Grill - MGM Installed Icon Stage 2 Kit. TRD Pro Wheels - 17's Ko2s installed (275 70 17) TRD PRO Rigid Led Fogs N Fab 3" Step Bars TRD Pro Auto Shift Knob TRD Pro Tail Lights
    What's your specs?
  20. May 31, 2016 at 8:23 PM
    #200
    BrettsMac08
    Kansas
    Update. Got the right tires on (load C) and properly road force balanced with the Toyota adapter plate for the wheels and it's smooth as can be from what I can tell. Steering wheel shake seems gone and the passenger seat no longer wobbles. Tested up to 75 on the highway, more like 77.5 adjusted for the tire size change anyway.
    Much happier now. Smoother ride too and the truck feels much lighter on its feet moving around and turning. I could immediately tell the difference.
    Still have to go back tomorrow though since the guy managed to break a TPMS sensor and had to order one since it's so new. Bit of a fail there. But oh well. Happy for now.
    Love seeing everyone else's setup.
