17" TRD Pro rims and BFG AT TKO2s...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BMunster, Apr 12, 2016.
  1. Mar 21, 2018 at 12:21 PM
    #1401
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    OK thanks. I'm new to this stuff and rubbing anything sounds like a bad idea so yeah I'm hoping everything will be ok, especially off road. Out of curiosity though, is it true that you can get anything to rub even stock?
  2. Mar 21, 2018 at 12:26 PM
    #1402
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    No clue. But my 265's rub every single time I pull into my driveway and have for 13 years. Other than making the noise and rubbing a little plastic off the mudflap, there is no issue. I think you're worrying about nothing. Just stay at 265 (or under) and you'll be fine.
  3. Mar 21, 2018 at 12:33 PM
    #1403
    ejewels
    CT
    Many people in this thread with third gens say no rubbing, unless you have mud flaps (which I don't). That includes driveways/bumps/off roading.
  4. Mar 21, 2018 at 12:47 PM
    #1404
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Off camber turns at full lock, usually when in reverse can rub at times, especially if you have mudflaps or the front airdam installed on the stock suspension with a +1 tire upsize depending on tire and wheel offset.
    It may never rub, it may always rub, each truck is different and what might be present on one truck may not be present on yours.
    I never rubbed on the stock suspension but I run a different tire than the KO2. I've never completely stuffed a tire because I don't rock crawl but I do enjoy offroading on fire trails, some mud and the beach.
    YMMV
  5. Mar 21, 2018 at 1:07 PM
    #1405
    ejewels
    CT
    Gotcha. So its still not a guarantee no matter what, I get it. I don't have the air dam, nor the flaps... so looks like I'll be good. If it just barely rubbed in very off camber/fully compressed situations I guess it doesn't really matter and not hurting anything. Anyways, I purchased the tires, but holding off on the wheels to bank some more cash for now.
  6. Mar 21, 2018 at 1:09 PM
    #1406
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    you'll be fine, quit worrying about it.
    1TonTomato and ejewels[QUOTED] like this.
  7. Mar 21, 2018 at 1:11 PM
    #1407
    ejewels
    CT
    If I go over a small bump and hear a loud rub sound, I'm blaming you guys!
    haha jk. Thanks for all the help.
    Anyone know what I can expect to pay to get these bad boys mounted? I'm in New England.
  8. Mar 21, 2018 at 1:12 PM
    #1408
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    I have no doubt that you would...
    You're welcome
    Ragrets and 1TonTomato like this.
  9. Mar 21, 2018 at 1:14 PM
    #1409
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Are your wheels not presently 16"?
  10. Mar 21, 2018 at 1:15 PM
    #1410
    ejewels
    CT
    I owe it to you, Stocklocker that gave me great info and assured no rubbing (even though I like to hear others say it as well). Thanks again. I'm currently on the stock 2018 off road wheels... 16"
    upgrading to TRD Pro 17" 4runners with 265/70/17 KO2 C rated...
  11. Mar 21, 2018 at 1:17 PM
    #1411
    Stocklocker
    17TRDORDCSBAT
    In case it is not clear, if you bought the 17" Ko2 you will need new wheels of some sort to fit those tires. They will not fit a 16" (inner diameter) rim.
    Nightscape likes this.
  12. Mar 21, 2018 at 1:17 PM
    #1412
    toyotatacomaTRD
    Granted, it's a little embarrassing when you rub carrying 4 co-workers to lunch that aren't into modding their Sienna or thier Oldsmobile Alero. It's funny to explain why it makes the rubbing sound, they just don't understand. But if it's just me, I'm so used to it, it doesn't even surprise me anymore. And hasn't for years.
  13. Mar 21, 2018 at 1:18 PM
    #1413
    ejewels
    CT
    You're in a third gen? I believe the third gen's have higher lift than previous
  14. Mar 21, 2018 at 1:19 PM
    #1414
    ejewels
    CT
    Sorry, updated my post so not sure if you saw it. I'm getting the same setup we had discussed and that you have... 17 pro wheels as well.
  15. Mar 21, 2018 at 1:19 PM
    #1415
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Call a tire shop and get some quotes for unmounting old tires from the original wheels to get to the TPMS sensors for transfer to the new wheels then mounting and balancing the new wheels. Could be $25 - 50 per corner is my guess.
    ejewels likes this.
  16. Mar 21, 2018 at 1:21 PM
    #1416
    Stocklocker
    17TRDORDCSBAT
    13 minutes ago, you were holding off on wheels, I see you've now moved forward on the wheel purchase. Post some pics when you get the set-up on.
  17. Mar 21, 2018 at 1:23 PM
    #1417
    toyotatacomaTRD
    My 3rd gen is being built next month. I'm here because I'm going with this same wheel tire setup. Just trying to ease your mind that if it does rub, no biggie.
  18. Mar 21, 2018 at 1:25 PM
    #1418
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Did you buy 4 tires or 5, you did make plans to replace the spare? That's also a 16 inch wheel in the OEM size.
    :devil:
  19. Mar 21, 2018 at 1:32 PM
    #1419
    ejewels
    CT
    haha nope... gonna risk it. Is it that bad to temporarily run on the spare to get home safe? People do it with donuts I suppose?
  20. Mar 21, 2018 at 1:32 PM
    #1420
    ejewels
    CT
    Sorry, what I meant was that I bought the tires first... and will wait a little bit to fund the wheels... just for financial reasons... but still planning on the wheels. Also, I shot you a PM ;)
