17" TRD Pro rims and BFG AT TKO2s...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BMunster, Apr 12, 2016.
  1. May 16, 2016 at 12:21 AM
    #141
    fortiz619
    fortiz619 yeh i drive a 2wd big woop wanna fight about it?
    Southern California , IE ,SD
    04 Tacito 5lug, 16 tundra, 07 tundra
    Not sure if uve been asked before but what size and what tire U running?,btw ur Tacoma looks awesome
  2. May 16, 2016 at 5:50 AM
    #142
    LawTaco
    LawTaco Well-Known Member
    Lawrence
    Bay Park,San Diego,Ca
    TRD SPORT 24
    QuicksandKna likes this.
  3. May 16, 2016 at 2:06 PM
    #143
    el_zorro1
    el_zorro1 Well-Known Member
    Zorro
    Northern Virginia
    Order placed...K02's with installer, waiting on the TRD wheels to be shipped...tic toc tic toc now the wait....pictures coming soon
    Gabevmd, mbmartin and OSHUCKS5 like this.
  4. May 20, 2016 at 4:51 AM
    #144
    el_zorro1
    Zorro
    Northern Virginia
    I joined the 'storm trooper' movement - and added a decal for that too :)
    265-70-17 KO2s, no lift, no rub, ... and the TRD 17s.
    arnette64, ISAN_TACO, goavs7 and 4 others like this.
  5. May 20, 2016 at 6:48 AM
    #145
    GNFGHTR09
    GNFGHTR09 Active Member
    Bill
    2016 MGM Tacoma TRD OR DCSB
    Just ordered the 17" TRD Pro's. Due to the offset would it be possible to run 255/75/17 without lift? According to tirerack only .5" taller than the 265/70/17, but about $50 cheaper per tire.
  6. May 23, 2016 at 7:47 AM
    #146
    Tedward
    Tedward Well-Known Member
    DMV/N. VA
    2016 DCSB TRD Sport 4x4
    Too many to list...
    Pulled the trigger, had my tires and tpms swapped from the stock wheels for $140 locally (DC area). Dealer wanted $260 to do it! BS. Now selling stock sport wheels... will be listing them shortly, but if anyone has a need message me!
    She's almost all black and blue...
  7. May 23, 2016 at 7:51 AM
    #147
    NYCPJM
    NYCPJM Well-Known Member
    2016 BBP TRD Sport 4x4
    TEDWARD, see you went with white lettering out? Did you consider Black side?
  8. May 23, 2016 at 8:38 AM
    #148
    Tedward
    DMV/N. VA
    Too many to list...
    Had the black side out on my stock wheels, switched sides for the TRDs for a change and little different look. Just gave it a little edge IMO.
    OSHUCKS5 likes this.
  9. May 23, 2016 at 11:08 AM
    #149
    quis23
    quis23 Well-Known Member
    Duan
    good ole' Manassas VA
    TEDWARD , who did you use for the swap ? I may need their services in a few weeks
  10. May 24, 2016 at 8:48 AM
    #150
    Tedward
    DMV/N. VA
    Too many to list...
    Sunset Hills Auto in Reston, VA. Dropped it off @ 7am, no real appointment, called me @ 9:30am to tell me it was done. Quoted me $170, charged $140 when I picked it up. Good service.
    el_zorro1 likes this.
  11. May 26, 2016 at 10:53 AM
    #151
    GNFGHTR09
    Bill
    I jumped on the bandwagon but when with Falken Wild Peak AT3's to save a little $$$$ for other mods.
  12. May 26, 2016 at 12:31 PM
    #152
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    I'll be doing the same.
    Anyone know where the best price is on these wheels currently?
  13. May 26, 2016 at 6:19 PM
    #153
    viking15
    viking15 Well-Known Member
    Joe
    What are those tires my friend
    I am torn between 265/70/17 and 265/65/17
  14. May 27, 2016 at 4:55 AM
    #154
    MasterPenguins
    MasterPenguins Well-Known Member
    Indiana
    2016 Quicksand Tacoma TRD Off Road 4x4, DCSB
    Quick question for all you guys that have pulled the trigger on this set up, have you just taken your truck to the dealer to get the speedometer and odometer calibrated after you had the bigger tires installed? This is something that just occurred to me as I was just about to pill the trigger on the wheels.
  15. May 27, 2016 at 6:16 AM
    #155
    GNFGHTR09
    Bill
    $700 on ebay
  16. May 27, 2016 at 6:17 AM
    #156
    GNFGHTR09
    Bill
    265/70/17 - come in at 31.65" and they dwarf the stock tires.
  17. May 27, 2016 at 6:20 AM
    #157
    GNFGHTR09
    Bill
    No, I did not. Depending on the manufacter the diameter between 265/70/16 (stock) and 265/70/17 is 1" to 1.70". To me it's not enough to effect the speedo to a significant degree 1.3% thereabouts I think.
  18. May 27, 2016 at 7:00 AM
    #158
    BlkTaco47
    BlkTaco47 Unhinged
    Thanks. Ended up finding them and bought em! Trying to get more info on the TPMS,
    the tire shop says a small "kit" is needed that contains a nut/washer? that has to used
    on the new wheel but so far all here have said nothing is needed they xfer right over.
  19. May 27, 2016 at 7:22 AM
    #159
    GNFGHTR09
    Bill
    What? You have stock TPMS now right? Nothing is needed. I went to Walmart Auto on my way to work and they transferred over the TPMS for FREE and was done in under an hour.
  20. May 27, 2016 at 7:30 AM
    #160
    BlkTaco47
    BlkTaco47 Unhinged
    Good to know, he may just be unfamiliar with them and not know.
