17 TRD PRO/SEMA Wheels
Discussion in 'Wheels & Tires' started by BigE, Mar 14, 2015.
  1. Jan 30, 2018 at 9:25 PM
    #241
    latin3
    latin3 Well-Known Member
    Katy TX
    2014 Super White Tacoma Prerunner TX edition 2.7L 4cyl
    4Runner TRD wheels Cooper Discoverer ATP 265/70/R17 OME 883 5100 bilsteins all around HS 1/4 spacer driver side Toytec single AAL
    Anybody change from the TX edition to the 17 trd pro/SEMA? Will I be able to use the same lug nuts and TPMS from the tx edition wheels to20180123_234902.jpg the SEMA Wheels?
  2. Jan 31, 2018 at 2:29 AM
    #242
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Funny you mention that, I just saw one for the first time yesterday walking through a parking lot at work, didn't think to snap a picture but they didn't look too bad. They might have been the FN version because it had black center caps instead of the TRD type.
  3. Feb 8, 2018 at 3:06 PM
    #243
    migs647
    migs647 Member
    So it looks like I purchased the knockoffs on eBay. The title of it even had TACOMA WORLD in the title and thought it was a deal for the site. I got the 17x8 black versions. I'm debating keeping them. Wondering if anyone has come across these and if they have had any issues?
  4. Feb 10, 2018 at 10:16 PM
    #244
    MilesNauticus
    MilesNauticus Active Member
    2007 Red Tacoma TRD
    Anybody got a pic of these on a Radiant Red taco. I'm hoping to ditch the tires and wheels on mine currently and slap a set of these on. BUT I'm torn between the gunmetal and black. I prefer the gunmetal but I think the black would probably look better. Any help is much appreciated.
  5. Feb 18, 2018 at 12:40 PM
    #245
    euroshowoff
    euroshowoff Well-Known Member
    Stafford, VA
    15 Superwhite DCSB 4x4 V6
    Toytec lift, Trailgear sliders, CBI ditch light brackets, Trailtoys LED ditch lights, Trailtoys LED reverse pods, Custom Roll-Bar, TRD skid plate, TRD sport grill, TRD custom bedsides, Custom BlueSea wiring block, OTTRAW Rockers, Pro Comp 7036, BFGoodrich KO2s, Bestop soft topper,VIAIR 88p
    I’ve seen these. Even say OEM. Wondering how they can get away without calling them oem “style”
  6. Feb 22, 2018 at 6:15 PM
    #246
    potziac
    potziac Member
    2016 Tacoma TRD Sport DCLB
    Do these wheels have a clear coat on them or do they have a textured finish? Just curious if they are somewhat porous and would retain dirt. For example, is the finish similar to the finish on the OEM predator step bars? They can be cleaned, but do not retain the darker black finish that they had when new. I was wondering if the wheels would be like that as well. Does anyone know? Thanks.
  7. Feb 24, 2018 at 1:27 PM
    #247
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Love all the pictures. Thanks to all how posted them and all the info These are going to be my next wheel in the gunmetal .
  8. Feb 24, 2018 at 3:57 PM
    #248
    latin3
    Katy TX
  9. Feb 25, 2018 at 7:36 PM
    #249
    JMB Glass
    JMB Glass Active Member
    Josh
    Brattleboro, Vermont, USA
    2018 Cement Off-Road DCSB auto with "Pro" mods
    Pro hood/scoop SEMA 4Runner Pro wheels Pro tail lights Non-Lux side emblem "black out" covers Deselen "TRD" emblem Pro skid plate Pro Rigid Industries Fogs with Amber covers OEM Pro front grille Pro TRD shift knob
    Curious if putting the Sema Pro's on my 2018 Off Road will mess with the tire pressure monitoring system
    (that shows the real time tire pressure). Is this an issue at all when changing wheels/wheel size? Thanks.
  10. Feb 25, 2018 at 8:21 PM
    #250
    blown ION
    blown ION Well-Known Member
    NJ
    2017 TRD PRO White
    Have the tech swap over the tpms from your original wheels into your new ones when mounting your new tires. Shouldn't be any issues. That's what I'm having done one day this week when my falkens come in.
  11. Feb 26, 2018 at 3:08 AM
    #251
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Only if you're installing steel wheels, they use a different TPMS sensor.
    The TRD Pro 4Runner wheels are alloys just like your Tacoma Pro wheels.
  12. Feb 26, 2018 at 4:30 AM
    #252
    JMB Glass
    Josh
    Thanks for the info on the sensors, sounds good. Is there a consensus about what size tires to go with
    on these Sema Pros so that there is no "rubbing" on the front mud guards on a 2018 OR as I've heard some
    here talking about earlier in this thread? Thanks again.
  13. Feb 26, 2018 at 4:49 AM
    #253
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    I run 265/70/17, now with a 2 inch lift, no mud guards but I wasn't rubbing at stock height either.
    2 inch lift
  14. Feb 26, 2018 at 5:04 AM
    #254
    JMB Glass
    Josh
    Thanks for that, doesn't look like you have the mud guards on tho? It sounds like any rubbing that folks were mentioning was against
    the front mud guards when turning wheels?
  15. Feb 26, 2018 at 5:52 AM
    #255
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    It's hit or miss on the mudguards at stock height, also depends on the tires you decide to run. Some real world measurements vary on 265/70/17 size tires especially if your running a more aggresssive tread.
    If it rubs you can either remove the guard and replace with thinner flaps or keep then off the truck completely.
    Or go with a smaller tire.
    What size tire does the TRD Sport run? It has 17 in wheels and can be had with mudguards.
  16. Feb 27, 2018 at 4:12 PM
    #256
    tacoma guy
    Joe
    Phoenix Az.
    Question for those that have these wheels. How hard are they to clean or keep clean? I ask because I heard they are not clear coat sealed. I am looking to get graphite.
  17. Feb 27, 2018 at 4:29 PM
    #257
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Not hard, they wash right off.
  18. Feb 28, 2018 at 4:21 PM
    #258
    tacoma guy
    Joe
    Phoenix Az.
    Awesome thanks!
  19. Feb 28, 2018 at 4:29 PM
    #259
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Here's a close up of my 2 year old wheel with 28k miles on the tires, they hold up pretty well.
  20. Feb 28, 2018 at 4:41 PM
    #260
    tacoma guy
    Joe
    Phoenix Az.
    I won't to get 265 70 17 Nittos with a 1 3/4 " lift up front will I get rudding? If so will removing the mud flaps take care of it? I have a 2011 DCSB Prerunner. Thanks inaadvance!
