17 TRD PRO/SEMA Wheels
Discussion in 'Wheels & Tires' started by BigE, Mar 14, 2015.
  1. Sep 29, 2020 at 8:56 AM
    #761
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    These are the 35/10.5/17 Kenda Klever, I trimmed front fenders and flares about 1/2”, aggressive cmc, smashed pinch weld and removed fender liner on the L side, kept it on the R for intake reasons. Running the OME 886 coils, SPC uppers with the HD Dakar pack in the rear. Wanting a re-gear but coming from 255/85/16s the transition wasn’t so bad and I can live with it for now.
  2. Sep 29, 2020 at 11:43 AM
    #762
    6Thick
    6Thick Well-Known Member
    Poconos
    2015 TRD Sport MGM 6MT
    TRD Pro Rims, BFKO2 265/70/17, ARE Shell, Leveling kit
    What? Now I’m worried. I just pulled trigger on these rims and some KO2s. Someone please chime in and tell me everything is going to be ok.
  3. Sep 29, 2020 at 11:47 AM
    #763
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Plenty of people are running KO2s on these wheels
    6Thick[QUOTED] likes this.
  4. Sep 29, 2020 at 11:48 AM
    #764
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    I asked Discount Tire about this and they said it wouldn't be a problem. Just check with your installer.
  5. Sep 29, 2020 at 11:58 AM
    #765
    6Thick
    Poconos
    How many different grey colors are there? Is there a “Matte Grey” and a “Gun Metal” grey?
  6. Sep 29, 2020 at 12:15 PM
    #766
    Iwilltaco
    Under development
    Yes
  7. Sep 29, 2020 at 12:22 PM
    #767
    6Thick
    Poconos
    Got it. There’s Matte Grey, Gun Metal Grey, Bronze, and Black?
    Iwilltaco[QUOTED] likes this.
  8. Sep 29, 2020 at 12:23 PM
    #768
    Iwilltaco
    Under development
    :thumbsup:
  9. Sep 29, 2020 at 2:05 PM
    #769
    6Thick
    Poconos
    Ok then, why come I can’t find a straight photo/ image showing each of the 4 different rim colors next to each other... to compare the colors?
    How different is the MatteGrey from the Gun Metal Grey?
    Also, I just read someone referring to a “Graphite” color as well.
    What gives?
    And what’s the difference between Sema, OEM, and Aftermarkets regarding these rims?
  10. Sep 29, 2020 at 2:12 PM
    #770
    Iwilltaco
    Under development
    Call it matte and gloss
  11. Sep 29, 2020 at 2:15 PM
    #771
    Iwilltaco
    Under development
    Sema is just a name, oem is the real thing, some places sell them as sema or 4Runner pro “style”. Usually means not oem.
    FN pro, many people run those, for more options
    6Thick likes this.
  12. Sep 29, 2020 at 2:20 PM
    #772
    6Thick
    Poconos
    Much obliged
  13. Sep 29, 2020 at 5:14 PM
    #773
    Kruuuzn
    Kruuuzn Well-Known Member
    Randy
    Traverse City, Michigan
    Oh, sorry bud. I didn’t mean to be negative. That was probably too much information. You’ll be fine.
    I wouldn’t give it a second thought if it were me. Honestly.
    And with the different offset on these wheels it pushes the rubber out 3/4”. The wider stance is a nice look. I just put these on my truck with some Coopers.
  14. Sep 29, 2020 at 5:28 PM
    #774
    onesixonetwo
    onesixonetwo Well-Known Member
    Do you know why these were called SEMA wheels? Did they debut at SEMA?
  15. Sep 29, 2020 at 6:31 PM
    #775
    Iwilltaco
    Under development
    I believe that is accurate
  16. Oct 4, 2020 at 2:12 PM
    #776
    Dampahee
    Dampahee Well-Known Member
    So Cal
    2019 TRD Off Road
    Fox Factory 2.5 extended travel w/DSC Eibach 650x14 springs Fox Factory 2.5 x 12 in smoothies with rr and DSC / Accutune Adventure tune Archive Garage shock relocation Archive Garage hammer hangers with 3.6" shackles Archive Garage high clearance cross bar Deaver Expedition u402 stage1leaf pack Camburg Racing Uniball UCA's Total Chaos Gusseted Spindles Marlin Crawler HD LCA/cam tabs Frame Brace gussets @weldstaco front diff reinforment kit Wheelers u-bolt flip kit with super-bumps Crown performance SS 24 in extended rear brake lines SS extended front break lines Exhaust re-route mod Dirt King Cab Mount Relocation OV Tune-91 Performance Nitro 5.29 Gears ARB Front Locking Differential ARB High output in board compressor Slee On-board compressor mount Blais Bros Taco differential breather mod Schmellfab 12.5° sliders with kick out RCI steel IFS skid RCI steel transmission skid RCI steel T-case skid RCI LCA skid BAMF Rear differential skid Relentless Fabrication hybrid front bumper Relentless Fab High Clearance rear bumper ATHF rear fender supports SOS performance rear disc brake conversion Trimmed Fenders 2.5" Softopper TRD Heritage grill RFT Raptor lights Morimoto XB headlights Baja Designs amber S2 flush mount chase lights Baja Designs S8 30 in lightbar Cali Raised Relay Mount Cali Raised cubby switch mount Smittybuilt X20 10 k winch Factor 55 Fairlead Factor 55 Flatlink E Factor 55 Flatlink Ropeguard Tandem Off Road Manor winch solenoid mount 1.25 inch Spidertrax wheel spacers 17x9 Ultra Wheel x103 beadlocks 35/11.5/17 Nitto Trail Grapplers Fend-X Wheel Liners Clazzio leather seat covers Taco Garage DMM Mount Taco Garage Anytime Front/Rear Camera MESO Customs Chrome Delete MESO Extended fuse cover AVS in channel low-profile wind visors Kicker CS tweeters, 6x9, 6.5's Kicker Key amp Kilmat sound deadening
    had anyone ran 35/11.5/17 trail grapplars on these wheels? I'm currently running 285-70-17 ridge grapplers with 0 rubbing. I'm trying tp figure out if i'll clear the uca and trying to avoid rubbing the frame, and I don't want to run spacers. I am aware however, that I will be doing a lot of other cutting. If I can't get this to work, I'll probably just run 285/75/17. Appreciate any input on this.
  17. Oct 5, 2020 at 8:20 AM
    #777
    spin180
    spin180 Well-Known Member
    WNC
    2022 Army Green TRD Off-Road DCSB
    This morning was one of happiness and joy.
    And then I found this:
    I'm not sure if the tire would hide the indentation completely. Even if it did, the displaced metal has created a small ridge/bump on the outward facing surface that would still be visible.
    There's not any damage to the box, so it seems to have happened prior to it being packaged by the manufacturer. Hopefully the retailer will replace it. Waiting to hear back now.
    I have (or had I guess) an appointment scheduled to get them installed this Saturday.
    :annoyed:
    -Rorschach- likes this.
  18. Oct 5, 2020 at 8:29 AM
    #778
    Iwilltaco
    Under development
    Had the same damage on mine. Looked like it was where the handle on the box exposed it to the harm of the outside world. My replacement arrived in 48 hours..
    spin180[QUOTED] likes this.
  19. Oct 5, 2020 at 8:31 AM
    #779
    spin180
    WNC
    I checked the box again to see if there was evidence of a breach around the handles, but didn't find anything obvious. Didn't see any corresponding marks on the plastic wrap or shower cap.
    Where did you get your wheels if you don't mind me asking?
  20. Oct 5, 2020 at 8:44 AM
    #780
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    The tire won't hide that. You should seek a replacement while trying to barter for that one as your spare.
