17" TRD SEMA Wheels and 265/70/17 Falken Wildpeaks tires = decreased MPG
Discussion in 'Wheels & Tires' started by 0314TrailEdition, Sep 26, 2023.
  1. Sep 26, 2023 at 5:28 PM
    0314TrailEdition
    0314TrailEdition [OP] Well-Known Member
    Colorado
    2023 Trail Edition
    A "testing her patience" Wife; Bilstein 6112 / 5160; Prime XR Plus on all windows; OEM Premium Headlights; OTT; Falken Wildpeaks / TRD SEMA Wheels; BAK Revolver x4s bed cover; alot of small interior stuff
    Has anybody put on 17" TRD SEMA Wheels with 265/70/17 falken wildpeaks and noticed the truck struggling a little, even with the OTT?
  2. Sep 26, 2023 at 6:38 PM
    eurowner
    eurowner Duke Sky
    Scoty
    You put taller and most likely heavier wheels and tires on, so yes.
    303tacoma likes this.
  3. Sep 27, 2023 at 6:12 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    What do you mean by struggle?
    I have aftermarket wheels and bigger tires on my trail edition and wouldn't say it "struggles" at all. Drives like it did with the stock wheels and tires with a hair more sluggishness but its barely noticeable. Goung up one size shouldn't make that much of a difference.
    I deff did take a 1-2 mpg hit.
  4. Sep 27, 2023 at 6:34 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Yes. No vehicle likes larger/more aggressive tread pattern in comparison to stock size/street tire. You can compensate with tuning all day long, and the drivability may be improved, but the truck is still ultimately working a little harder to rotate the upgraded wheel/tire setup.
  5. Sep 27, 2023 at 6:44 AM
    0314TrailEdition
    Colorado
    2023 Trail Edition
    I guess struggles is a strong word. It just doesn't hold the gears (really sixth) quite as along as it used to. I am also at 7200 ft.
  6. Sep 27, 2023 at 7:04 AM
    fourfourone
    I would say that's normal then.
    A tune can only do so much to help for the lack of low-end power these trucks have.
  7. Sep 27, 2023 at 7:28 AM
    eurowner
    eurowner Duke Sky
    Scoty
    At 7100' up in elevation there is roughly a 21% loss in horsepower due to the 'lack of oxygen'. Adding weight, especially heavier wheels make it more noticeable.
    I live at 7000. Use ECT and Smode when ascending. These V6 engines love to rev in the higher rpms, do not low rpm lug it!
