17" wheels to replace 16" stock???
Discussion in 'Wheels & Tires' started by Jdog73, Oct 20, 2014.
  1. Oct 20, 2014 at 8:28 PM
    Jdog73
    Jdog73 [OP] Active Member
    Pocatello Idaho
    12 Tacoma SR5 L/B
    Just bought a 12 SR5 with ugly stock steel wheels. Can I safely put the 17" alloys that come on a TRD sport? Or am I best to stick with 16. I'd like to get a taller look without a lift. ?? First photo is my nasty steel wheels. Other pic is regular alloys I want. Thx.
  2. Oct 20, 2014 at 8:42 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    If you stay mostly on pavement, 17" works better.
  3. Oct 20, 2014 at 9:11 PM
    Jdog73
    Pocatello Idaho
    12 Tacoma SR5 L/B
    I am 75% freeway so for sure. But wasn't sure if the change affected speedometer or other issues?
  4. Oct 20, 2014 at 9:36 PM
    KenLyns
    Belly of the Beast
    A bigger wheel won't get the truck taller. Only way to do that would be to get a larger-OD tire. Stock tires, regardless of base, SR5, or TRD, are all 31" OD. You can go up to 32" OD without trimming the fender flare plastic.
    Stock speedometer calibration is intentionally optimistic. Going from 31" to 32" tire actually makes the speedo more accurate. The odometer will then under-report by about 3%, but that's typically to your benefit.
  5. Oct 20, 2014 at 9:44 PM
    SWOreBowHunter
    SWOreBowHunter Well-Known Member
    Oregon
    '14 AC 4x4
    Front: 5100s and 884x Rear: Dakars and OME Nitrochargers
    How?
  6. Oct 20, 2014 at 9:51 PM
    KenLyns
    Belly of the Beast
    ^Lower profile sidewall means more responsive tire when cornering, while still having enough sidewall to prevent hardness over potholes.
    Stock Jeep Wrangler wheel is 18" on the Sahara trim, FYI.
  7. Oct 20, 2014 at 10:27 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    the wheels you want aren't 17's. those are the stock 16's with the TRD Off Road package.
  8. Oct 20, 2014 at 10:59 PM
    Jdog73
    Pocatello Idaho
    12 Tacoma SR5 L/B
    yeah I realized after i put that pic up that was a TRD off road. It is the TRD sport that has the 17s. So maybe I should just stay with the 16 Rim and just get a bigger diameter tire. I know for sure I need to get an alloy wheel on and get rid of those ugly steel things.
  9. Oct 20, 2014 at 11:02 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Just find a local Toyota dealer who does a lot of upgrading/upselling to the trucks they sell. They'll likely have a set of alloys off a sport and some tires that someone didn't want/pay for and may be willing to give you a good deal for them.
    That or the buy and sell on here is always full of takeoff's.
  10. Oct 20, 2014 at 11:09 PM
    Jdog73
    Pocatello Idaho
    12 Tacoma SR5 L/B
    so there seems to be no reason why I should avoid putting the 17 inch wheel and whatever tire they came stock with on mine???
  11. Oct 21, 2014 at 12:17 AM
    SWOreBowHunter
    Oregon
    '14 AC 4x4
    It depends if you like the 17" look. If you do, you can pair them with 265/70/17 skins and get a little lift (from tire size). IMO, 16s look better. They would go with 265/75/16.
    Keep in mind, you may have some rubbing with this tire size.
  12. Oct 21, 2014 at 7:46 AM
    Jdog73
    Pocatello Idaho
    12 Tacoma SR5 L/B
    I guess if the wheel size doesnt affect the height at all I would rather stick to the 16s and just get a slightly taller tire. 265/75/16. Anyone have experience with this size on an SR5 with no lift?? Could I do a leveling kit - Would that make any difference on not rubbing or am I going to need a lift??
  13. Oct 21, 2014 at 9:29 AM
    KenLyns
    Belly of the Beast
    265/75-16 on stock wheels and stock suspension should have no rubbing.
  14. Oct 21, 2014 at 10:21 AM
    Jdog73
    Pocatello Idaho
    12 Tacoma SR5 L/B
    Ya I have been watching. I missed a set og 16s with BFGs for 200 for the whole set on my local classifieds. Looking at a set right now that have 600 miles on them for 320.
  15. Nov 6, 2014 at 6:51 PM
    taylola2010
    taylola2010 Well-Known Member
    Lauren
    Columbus, GA
    2015 Prerunner SR5
    I'm in the same boat. I want some black wheels but not ready to change stock suspension and tires yet.
