17" x 7.5 rims
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006WorkHorse, Nov 26, 2021.
  1. Nov 26, 2021 at 10:32 AM
    2006WorkHorse
    2006WorkHorse [OP] It's always something!
    Gregory
    2006 Radiant Red Tacoma TRD Sport SR5
    Stock Access Cab, 4x4, V6, 6speed
    "New to me" 2006 Tacoma owner here, access cab, 4x4, 4L engine, manual six speed, love this truck, but original rims are corroded and leaking air slightly at the bead. Can I use "17" x 7.5 rims" off a later model Tacoma? I know the lug pattern works, but I don't know a whole lot about "offset" and changes to the wheels in later models. Thanks for anything and everything!
  2. Nov 26, 2021 at 4:22 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to the forum! 2nd Gen and 3rd Gen wheels are interchangeable, so you can swap any 6 lug Tacoma wheel from your year to the current year without issue.
    Edit: same goes for 4Runner or modern FJ wheels.
    lo2hi and TnShooter like this.
  3. Nov 26, 2021 at 4:57 PM
    2006WorkHorse
    Gregory
    "you can swap any 6 lug Tacoma wheel from your year to the current year without issue."
    Thank you crashnburn80, I'm about to purchase nearly flawless stock 6 lug 2012 rims for my 6 lug 2006 and this provides confidence. I'll check back and add a photo after the purchase and the swap! Thanks to you, Best to all.
    lo2hi, crashnburn80 and skeletron like this.
