17s or 18s?
Discussion in 'Wheels & Tires' started by Lane Cypert, Mar 15, 2009.
  1. Mar 15, 2009 at 6:48 PM
    Lane Cypert
    Lane Cypert [OP] Well-Known Member
    Lewisville, Texas
    2008 silver prerunner double cab TRD
    I am ordering my lift this week and I am trying to decide whether to get 17 or 18 inch wheels. I know that with a 3 inch lift I can run 265/70 17s but what size of 18s can I run without rubbing?
  2. Mar 15, 2009 at 6:57 PM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
  3. Mar 16, 2009 at 6:11 PM
    Lane Cypert
    Lewisville, Texas
    I was wanting to know what size 18s I can run with a 3 inch Toytec Coilover lift and If I could go bigger than 265/70 17s without rubbing/trimming.
  4. Mar 16, 2009 at 6:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    285/60/18 with no rubbing (what Im running)
    285/65/18 with a little rubbing.
  5. Mar 16, 2009 at 6:27 PM
    rpoint16
    Tempe, AZ
    Bone Stock
    I'm still working on mine. I have the OME 885 & N140s up front. It started out with a 3" lift but has settled to a 2". Not too happy right now. I have 265/70/17's & I have had to cut out quite a bit under the fender. I just ordered some top plates which should give me an additional 1/2"-5/8". We will see.
    But, mine is a 4X4. Your prerunner is not as heavy up front. Ask Toytec (email in writing) what you can expect as far as a height increase. I know some guys here in town are running 285's with some rubbing.
    A 265/70/18 is 10.43" X 32.61" which on a nice rim, is good sized. A 285/70/18 is 11.22" X 33.71", which is HUGE! :eek:
    Hopefully someone else can chime in.
    Good luck!
  6. Mar 16, 2009 at 6:38 PM
    Lane Cypert
    Lewisville, Texas
    Thanks for the help guys! Chris would I experience any rubbing of the stock UCA with a 3 inch coilover lift on the front with running 285/60 18s or 265/70 17s. The wheels I will be running are 4.5 backspace with -12 offset. I just wanted to make sure I wouldn't be rubbing the uca at all before buying my wheel/tire combo. Thanks again!
  7. Mar 16, 2009 at 6:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think you will be fine. :) No rubbing on the UCA.
  8. Mar 16, 2009 at 6:55 PM
    Lane Cypert
    Lewisville, Texas
    I am glad to hear I should be fine on either the 17s or 18s. Thanks again for your help Chris!
  9. Mar 16, 2009 at 6:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yw. :)
