17x7 and 17x8
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDsport253, Mar 17, 2010.
  1. Mar 17, 2010 at 1:19 AM
    TRDsport253
    TRDsport253 [OP] Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    So will i have rubbing issue if i swap my tires from the sport rims which are 17x7 with konig countersteer type x that are 17x8. No lift, and the tires are bfg all-terrain 265/70. I hear that they will rub because konig are wider than the stock sport rims. Also, i still have my stock bridgestone dueler tires 265/65, will those mount on the konig 17x8?
  2. Mar 17, 2010 at 1:21 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    what is the backspacing on the rims you are looking to get? if the 265/70 will mount, the 265/65 will since they are the same width
  3. Mar 17, 2010 at 5:24 PM
    Blacoma
    Blacoma Well-Known Member
    Broken Arrow, Oklahoma
    09 Black PreRunner w/SR5 TRD Sport Pack.
    Westin Bull bar and skid plate, leveling kit, chrome tailpipe tip, window vent visors, dark tint, scangauge2, shorty antenna.
    I put 265/70's on mine with 17 X 8.5 wheels and didn't have any problems. Later added a leveling kit but not because of any rubbing issues. Can turn the wheels all the way without any problem.
  4. Apr 6, 2010 at 10:32 PM
    LAtacoma
    LAtacoma New Member
    06 Prerunner TRD Off Road
    Countersteer X are 17x8 with -10mm offset. I have these wheels, 265/70/17 BFGs, Bilstein5100s at 1.75", mudflaps removed and they rub slightly from time-to time. The BFG's square shoulder and the negative wheel offset put the outside shoulder of the tire really close to rubbing on the back portion of the front fenders when turning (especially turning and hitting a bump). If you go with that setup Id recommend 1.75-2.5" lift. Good luck. . .
