17x8 Konig CounterSteer Type X
Discussion in 'Wheels & Tires Marketplace' started by JdMeF9SiR2, Jun 7, 2010.
  1. Jan 14, 2022 at 6:50 PM
    #1121
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Logic would say yes. But I don't know if that translates to real world results. I would love to know your experience if you make the switch.
    GoldenTaco27 likes this.
  2. Jan 14, 2022 at 6:57 PM
    #1122
    GoldenTaco27
    GoldenTaco27 Well-Known Member
    Blake
    Long Beach Ca
    2017 Tacoma DCSB TRD Off Road
    @hungoverland on IG, King 2.5" EXT Travel w/ Archive Garage shock relocation, Icon RXT leafpack, 285 Nitto M/T's, bronze Raceline Defender wheels, TJM front/rear bumpers, TJM Sliders, Prinsu Cabrac, Katzkin leather, RSI Smartcap EVO topper, OV Tuned, MESO everything, Spyder headlights and tail lights, center mounted infant restraining system (CMIRS) \m/
    Thats what I am thinking... real world results would probably be almost impossible to see/feel despite the 23% reduction of rotational mass on each corner. Curious to see if anyone says differently though :notsure:
  3. Jan 14, 2022 at 6:59 PM
    #1123
    su.b.rat
    su.b.rat broken truck
    that all depends on the driver, but i think you'd feel it if you're looking for it. 6lbs is significant for unsprung weight.
    i have run Six Shooters for years, they are like 24lbs or something. next week I'm mounting up a new set of Volks which are 17lbs give or take. it's taken a lot of effort to get those and for the same reasons you mentioned and more. and i really like E tires on light wheels, because they are less compliant and allow for a lot more road feel to get to the driver.
    if you really want to experience a difference in the driving, then get a set of Wilwood brakes for the front. they are 17lbs lighter than stock per side unsprung weight. that is huge. it made the truck much nicer to drive, more responsive, and of course better braking.
    https://www.summitracing.com/int/se...=part-type&SortBy=Default&SortOrder=Ascending
    GoldenTaco27[QUOTED] likes this.
  4. Jan 14, 2022 at 7:08 PM
    #1124
    CowboyTaco
    North Georgia
    11 TRD Sport
  5. Jan 14, 2022 at 7:23 PM
    #1125
    GoldenTaco27
    Blake
    Long Beach Ca
    That's an insane weight difference for something that out preforms to OEM. I have the Powerstop setup for slightly less coin :spending:... unsure if that was a weight savings or not, but they work better than OEM for sure. If I can get a deal through my neighbor.... I would consider giving the Wilwoods a shot though. Thanks for the info!
    su.b.rat[QUOTED] likes this.
  6. Jan 14, 2022 at 10:06 PM
    #1126
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Another brake option with 17's is OEM 5th gen 4runner brakes.
  7. Feb 4, 2022 at 2:14 AM
    #1127
    LongDistanceTaco
    LongDistanceTaco Well-Known Member
    Geoff
    California
    Is the conversion a bolt on or did you need some sort of bracket for the caliper to fit?
  8. Feb 4, 2022 at 7:32 AM
    #1128
    su.b.rat
    the Wilwood kit is plug & play.
  9. Feb 25, 2022 at 4:10 PM
    #1129
    tacos89
    tacos89 Well-Known Member
    Charlotte
    2018 4x4
    does this fit 3rd gens with camburg UCAs?
  10. Feb 26, 2022 at 4:00 PM
    #1130
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I would think so. I'm running these on a 1st gen Tacoma with Camburg UCAs.
  11. Feb 26, 2022 at 5:43 PM
    #1131
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    The wheels? I have a 2nd gen with camburg uca’s and yea they clear
  12. Mar 10, 2022 at 7:37 AM
    #1132
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Has anyone run these with skinny 33's? I'm thinking of getting 255 80 17 wildpeaks.
  13. Mar 10, 2022 at 9:49 PM
    #1133
    couplefunones
    couplefunones Well-Known Member
    No issues with 255/80/17. Haven’t tested with low PSI though
    beez and boostedka like this.
  14. Mar 11, 2022 at 4:22 AM
    #1134
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Looks sweet, man first gen regular cabs look awesome.
    beez and couplefunones[QUOTED] like this.
  15. Mar 14, 2022 at 1:11 PM
    #1135
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Anyone selling a used set?
  16. Apr 1, 2022 at 8:27 PM
    #1136
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    Just placed an order for a set in blue!
  17. Apr 1, 2022 at 8:42 PM
    #1137
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    They said they were in stock but. I called to ask and see if they had any. Thought about getting a set of blue too
    c_walters[QUOTED] likes this.
  18. Apr 1, 2022 at 8:58 PM
    #1138
    c_walters
    Mooresville, Nc
    did they say they had them?
  19. Apr 1, 2022 at 8:59 PM
    #1139
    vorkuta775
    Texas
    tesla truck
    Nope. Dustin is prob busy AF. I'm aure he will call back. I want a set of blues . I'll sell my volks
  20. Apr 1, 2022 at 9:33 PM
    #1140
    c_walters
    Mooresville, Nc
    man, hopefully they have them soon :annoyed:
