17x9 DC-1s -12 mm on stock 265/65-17s with no lift
Discussion in 'Wheels & Tires' started by Joe B, Mar 22, 2009.
  1. Mar 22, 2009 at 9:00 AM
    Joe B
    Joe B [OP] Well-Known Member
    I love these friggen wheel but before I order these wheels....
    Any rubbing issues?
    How far out the wheelwell are the tires?
    Pics?
  2. Mar 22, 2009 at 9:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Im thinking the tires will stick out an inch further than stock.....
    Anyone else have any input??
  3. Mar 23, 2009 at 8:30 AM
    SnoBoarder
    SnoBoarder Hardcore wheeler, try and keep up.... if you can.
    Lost
    85 4Runner - Built not Bought
    Maybe this will help, or not... FoxySandChick has 17x9 moto metals 957's which spec out as 4.5 backspace / -12mm offset. From her pic in post#6 it looks like no lift and she mentions some rubbing at full turn on the fender corners. No front mud flaps are present. Her profile says she has the TSB bilsteins and she has slightly larger tires than yours, 265/70/17's, but it may give you a visualization.
    http://www.tacomaworld.com/forum/wheels-tires/19647-anyone-running-265-70-17s-nitto-tgs.html
  4. Mar 23, 2009 at 8:51 AM
    Joe B
    Thanks,Sno.
    The tires don't seem to stick out too far from that angle.
    Like you said,she has 265/70-17s which according to Discount Tire's tire calculator is .52" more sidewall height and a bigger overall diameter of 1.05 and circumferance 3.27 than my stock 265/65-17s.
    Maybe I won't need any trimming or have to take off the mudflaps.I really wish I knew before buying these wheels.:eek:
  5. Mar 24, 2009 at 2:18 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Thanks :D. You are correct.
    I answered your PM with the pic that is also in the above thread, post #14. I'm thinking it sticks out maybe an inch, I don't think it is so much that you would get a ticket or anything. Your size will be about 1" smaller than mine, I'm pretty sure there wouldn't be any rubbing. I should take a pic of the area it is rubbing, it is a very small corner on the inner edge of the bottom of the fender and it only rubs on full turns. I have no problems with the rear edge rubbing, so I think your mud flaps would be fine. Hope this helps. I'll try to remember to get some pics when I'm not working and it is light out ;).
