17x9 on a 275 or 285
Discussion in 'Wheels & Tires' started by prerunner32, May 29, 2012.
  1. May 29, 2012 at 2:56 PM
    prerunner32
    prerunner32 [OP] TRD
    Alan
    Foothill Ranch
    05 Prerunner TRD Sport Longbed
    285/70/17 BFG A/T's, 17in Method Double Standard Wheels, Camburg 2.5 Coilovers, Alpine Head Unit, Infinity Speakers, 10" JL Audio Sub, 2 Rockford Fosgate Amps, AFe Stage 2 Si (Oiled)
  2. May 29, 2012 at 2:59 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Your gonna have to trim with 285's so the other sizes would actually fit better.
  3. May 29, 2012 at 3:02 PM
    prerunner32
    Alan
    Foothill Ranch
    Yea understand the trimming I was only curious if the width of the rim would be to wide for 275's or 265's. I dont want the rim sticking out farther than the tire at all.
  4. May 29, 2012 at 3:28 PM
    Kougr
    Kougr Active Member
    Antelope, CA
    06 Tacoma DC 4x4 TRD
    5100's w/OME-885s
    All the tire data I've read says LT265s and LT275s fit on a rim with a max width of 8.5. Will they fit a 9" rim?
  5. May 29, 2012 at 4:42 PM
    TacoLife08
    TacoLife08 Well-Known Member
    GA
    08 DC PreRunner TRD Rugged Trail SR5
    Camburg 4' Spindles, top plate spacers, 2" AAL, 285/75R/16 Terra Grapplers, Tinted Windows, Black Riveted Grille, Black Spyder Halo Healights/Tailights, FlowMaster 40 Exhaust, NFab Side Steps, Blacked out Skid Plate.
    ya i would not recommend a 265 on a 9" width rim at ALL!
  6. May 29, 2012 at 5:28 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Many 265s are approved for 9" wide wheels but some are not. You can check on the tire manufacturers website.
  7. Jun 8, 2012 at 9:09 AM
    09 Redneck
    09 Redneck Well-Known Member
    Ga
    I have 17x9 XDs and run 265-70-17 toyo open country a/ts. Got 43000 miles on them so far. No problems and they fit the rims perfect.
  8. Jun 9, 2012 at 3:50 AM
    mrw3685
    mrw3685 Well-Known Member
    TX by way of KS
    08 Prerunner TRD
    Maxtrac Spindles, Bilstein 5100s all around, set at .85, Allpro Expedition Leaf Pack, Procomp 7036 17x9, w/Nitto Trail Grappler 285/70/17, Extended Steel Braided Brake Lines, Red-Line Hood lift, Relocated Trailer Connection, Trimmed Front Fender.
    I have those rims with 285's. Search my threads you'll find pictures.
  9. Aug 3, 2013 at 12:32 PM
    ABAKES
    ABAKES New Member
    Andrew
    Southern California
    2012 4WD DCLB MGM SPORT
    WEATHERTECH FLOOR LINERS, SNUGTOP REBEL SHELL W/ CARPET KIT, YAKIMA ROOF RACKS,
    i know this is an old thread but i have been trying to research the same answer for a while and hope this helps anyone in the same position.....
    i just had BFG All terrains 265 70 17's put on a method standard 17 by 9.... i like the way it looks as far as the distance it sits out from the wheel wells.... but the tire does not have enough of a sidewall so if i hit the curb its goin to damage the rims instead of hitting the sidewall of the tire. im switching them out for 17 by 8.5's, which is the suggested size anyway. i got those rims because i was going to go with 285 70 17's but chickened out at the last second because i didnt want to have to deal with trimming.
