17x9 with 5" BS/0 offset. work on stock suspension?
Discussion in 'Wheels & Tires' started by bmiller541, Dec 11, 2012.
  1. Dec 11, 2012 at 12:05 PM
    bmiller541
    bmiller541 [OP] Active Member
    Looking to pick up some XD Eduros's. They are used but in great condition, but I also don't know the exact specs on them. I looked online and it looks like they are either 4.5" or 5" backspacing w/ 0 offset.
    Right now I have stock suspension with 265/70 r17s. Will this work out? the tires will fit a 9" rim
  2. Dec 11, 2012 at 3:22 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    What year is your truck?
  3. Dec 12, 2012 at 7:36 AM
    bmiller541
    2012 4x4 DCSB TRD sport
    I guess the wheels are actually -6 offset and 4.7" BS.....
  4. Dec 12, 2012 at 7:50 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I suspect you'll rub a bit without a bit of lift. I have 17x9 wheels with 4.5 BS and 265/70-17 Duratrac's with roughly 2.8" of lift up front, and I rub a tad in reverse at full lock.
  5. Dec 12, 2012 at 7:59 AM
    bmiller541
    I can live with a little rub. I plan on going with a 2-3" lift anyway.
    I found a guy that has 17x9 XD Enduros in new condition.
  6. Dec 12, 2012 at 8:32 AM
    Fabulous
    Fabian
    Calgary, AB
    I'd put a lift on prior to doing the wheels just to be safe. When I bought my truck I had the stock TRD Sport wheels with 265/70-17 Bridgestone Revo's, and even then I rubbed a tad. With 17x9 wheels with 4.5 BS the outer edge of the wheel is roughly 2.5" further out in the wheel well, so I almost guarantee it'll rub, and probably worse than what mine does.
  7. Dec 12, 2012 at 10:11 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    As long as you can deal with some rubbing, you'll be ok. The main concern is that you're not going to run on your UCA. Full lock rubbing happens on most setups. Just do some plastic trimming, mud flap removal, and you'll be fine for street driving.
  8. Dec 12, 2012 at 2:19 PM
    bmiller541
    I can deal with some light rubbing/trimming. I'll probably throw a small lift/leveling kit in soon too so that should help! So just to clarify, 4.7" BS w/ a -6 offset will NOT hit the UCA...
  9. Dec 12, 2012 at 3:46 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Correct.
