-18 offset
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dutchcontractor, Jan 9, 2021.
  1. Jan 9, 2021 at 7:05 PM
    dutchcontractor
    dutchcontractor [OP] Well-Known Member
    Time has come for me to buy some nice wheels and tires.
    My focus is on the 17" black rhino arsenals.
    BUT they only come 9.5 inches wide with a -18 offset. My calcs tell me that that's almost 2 inches offset difference than the stock wheels. I would like to run 275/70/R17 on them. I'm on a 2"lift.
    Are my hubs going to be screaming? Is it too much poke? Can I even put 275 tire on a 9.5 inch wheel?
    Any insight would be great.
  2. Jan 9, 2021 at 7:31 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    275 would be a little too skinny , especially for a black rhino arsenal wheel which is typically an off-road wheel. I'd recommend upgrading to a 285 or 295 if you can.
  3. Jan 9, 2021 at 7:37 PM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    You should be okay with 275/70r17s, and I would think your hubs would be fine, I've been running wheel spacers and larger wheels/tires than those for a while with no particular issues. It will be some significant poke, and as others have mentioned you will have a basically flat tire with that wheel/tire combo where you usually want the tire a little wider than the rim
    Jpalafox likes this.
  4. Jan 10, 2021 at 11:16 AM
    dutchcontractor
    Thank you! I wish that made that wheel less wide with a smaller offset for Tacoma. I may just have to go with the 16" x8" -10mm version. I trying to avoid any trimming and really not looking to have my tires stick 2" past my fenders.
  5. Jan 30, 2021 at 4:29 PM
    Greg Hall
    Greg Hall Well-Known Member
    Greg
    Pittsburgh PA
    2016 Tacoma OR
    Im looking at a similar setup and in the same predicament... Black Rhino makes a 17 9.5 +12 offset. I am considering going with these wheels and adding a 12mm wheel spacer to get me at offset of zero. Would be putting 265 70R17 on stock height. This logic puts those tires flush I would think. This may be an option for you.
  6. Jan 30, 2021 at 4:53 PM
    dutchcontractor
    Good tip! I just looked up that wheel. That'll give me some more flexibility!
    Greg Hall[QUOTED] likes this.
  7. Jan 30, 2021 at 5:16 PM
    Greg Hall
    Greg
    Pittsburgh PA
    2016 Tacoma OR
    Tons of flexibility! Likely the route I’m taking as well.
  8. Jan 30, 2021 at 5:37 PM
    Greg Hall
    Greg
    Pittsburgh PA
    2016 Tacoma OR
    Good point man. Looks like the black rhino wheels are 15lbs more per wheel than stock alloy. Im running falken tires now on stock and curious how the extra weight will affect with the same tire. I could see an extra 15# having an effect.
  9. Jan 30, 2021 at 5:44 PM
    dutchcontractor
    Good advise!
    The combo I'm looking at isn't horribly heavy. Wheels are 35lbs and tires 50lbs. Which puts me at 85 lbs total. Stock I'm at 25 for wheels and 39 for wheels.
    egb1776 likes this.
  10. Jul 12, 2021 at 7:06 AM
    RD8761
    RD8761 Member
    2019 Quicksand Tacoma TRD Off-Road
    I ran 17 X 9.5 +6 armory wheels with 33 X 10.5 Wrangler MT/R's for a short time and the tires sat approx .5" further out than factory. With a 1.5" front leveling block there was zero rubbing. The weight was a killer. Even living in flat central Indiana my truck would struggle going up any hill on the interstate. Eventually change my setup to the 16 X 8's with wrangler duratracs. Truck performs much better with the lighter wheels and an Orange Virus tune upgrade.
  11. Jul 12, 2021 at 8:53 PM
    Toco62
    Toco62 Well-Known Member
    I just did a 2" front and icon leaf pack to the rear, 275 70 17 on fuel rebel 6 , 17x 9 with -12
    Did a minor mod to the front of wheel well , removed mud flaps and front air dam . no rubbing at all .
    If you are in Arizona call Eric at State 48 or Ben at Toy Pros, they are amazing to work with.
    Junkhead likes this.
  12. Jul 13, 2021 at 5:42 AM
    JP3
    JP3 Well-Known Member
    JP
    2020 SR5 /DCLB /MGM//////B7 Audi RS4
    285/70/17 Falken WildPeak on Stealth 6 Eibach Lift
