18" rims.. good or bad?
Discussion in 'Wheels & Tires' started by juicyj, Apr 21, 2012.
  1. Apr 21, 2012 at 4:40 PM
    juicyj
    juicyj [OP] Member
    jay
    mississippi
    06 tacoma 4x4 access cab base model
    so im in the market for some new tires and rims and iv read that a 265 70 17 is the largest tire size ican put on my stock truck. so if the 265 70 17 is roughly a 31.5" tire and a 265 65 18 is about the same could i run the 265 65 18 without any prob or mods?
  2. Apr 21, 2012 at 4:44 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Yes, you can run 265/65/18 with no problems. You can see pictures of that size in my build. I have a lift now, but they fit fine before I got it.
  3. Apr 21, 2012 at 4:47 PM
    juicyj
    juicyj [OP] Member
    jay
    mississippi
    awesome thanks man.. im planning on getting a lift/leveling kit any ideas on what size i should think about.
  4. Apr 21, 2012 at 4:48 PM
    KPT
    09 Prerunner
    :notsure: it's up to you
  5. Apr 21, 2012 at 4:51 PM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    5100's set at 1.75 will be perfectly level with stock suspension
  6. Apr 21, 2012 at 4:58 PM
    juicyj
    juicyj [OP] Member
    jay
    mississippi
    are the 5100's very pricey? i was thinking like a 2" front spacer and add a leaf in the rear..
  7. Apr 21, 2012 at 4:59 PM
    KPT
    09 Prerunner
    They are under $200. It's a good rule of thumb to avoid spacers. if you do a search you will have hours of reading on it.
    Search for "spacer bad" or something like that.
  8. Apr 21, 2012 at 5:06 PM
    juicyj
    juicyj [OP] Member
    jay
    mississippi
    thats whats up! thanks again. super nice build bty.. mine is white and i hope someday it will look as clean as yours
  9. Apr 21, 2012 at 5:09 PM
    juicyj
    juicyj [OP] Member
    jay
    mississippi
    hey what does "offset" mean on the rims iv noticed there are several different options available?
  10. Apr 21, 2012 at 5:11 PM
    KPT
    09 Prerunner
    Here, this link will tell you all you need to know about wheels.
    https://www.rsracing.com/tech-wheel.html
    When looking for wheels for our trucks, look for a 6x139.7 or 6x5.5 bolt pattern, and a backspacing between 5.5" and 4.5" since you want to run 265s.
  11. Apr 21, 2012 at 5:24 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    DA-DA-DA-DA-DA- KPT to the rescue on tire and wheel questions again!
