18 Tacoma Belt or Pulley Squeal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaMike25, Jan 5, 2023.
  1. Jan 5, 2023 at 4:07 PM
    TacomaMike25
    TacomaMike25 [OP] Well-Known Member
    2012 Tacoma SR5 4cyl 4x4
    2 inch lift, Level 8 Mk6 wheels 16x8 with a 275/85r16, Aftermarket fogs with yellow bulbs, AVS bug deflector, Weather Rain guards, secondary air filter delete. PIAA halogen bulbs
    Hi everyone. I have been having this on and off again squealing coming from the engine. Up in the northeast the weather has been all over from single digits to 60 degrees. Over the past few days the squeal I had in November came back. I made 3 videos on different days and temps in the 50s/60s of the truck doing this. Wanted to get some input if it would be covered under warranty. My truck is a 18 TRD OR with 51k mi. I purchased the extendo warranty for it.
    I would imagine the day I make an apt to the dealer it wont make the sound and I will show them the videos and they will say “we can replicate the sound” and send me on my way just like I would expect.
    https://youtube.com/shorts/9uDNflJvFFY?feature=share
  2. Jan 5, 2023 at 4:13 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    sounds more like a wet belt.
  3. Jan 5, 2023 at 4:25 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Hard to tell, but check and be sure a bearing isn’t starting to seize.
    I haven’t tried it on a Taco, but if you have an infrared thermometer, you can point it around different parts to see if anything is getting hot that the belt goes around Run engine for awhile and then test with it turned off- nothing should be much hotter than 200° or so.
  4. Jan 5, 2023 at 4:32 PM
    Bishop84
    Bishop84 Well-Known Member
    Typically a belt, there’s even a tsb for early 3rd gens saying don’t diag just toss a belt on.
    shakerhood likes this.
  5. Jan 5, 2023 at 5:51 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    I saw this TSB. Try the belt, I would get the OE belt Toyota listed in the bulletin.
  6. Jan 5, 2023 at 6:01 PM
    eurowner
    eurowner Duke Sky
    Scoty
    The serpentine belt tensioner will make a noise like that when it’s failing
  7. Jan 5, 2023 at 6:06 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Sounds identical to the noise I had. Put a new belt on and it's been good.
  8. Jan 5, 2023 at 6:14 PM
    Barcelona21Taco
    Barcelona21Taco Well-Known Member
    21 OR
    Give the belt a light spray of water when the engine is running. The water will lubricate the belt enough to make it stop squealing if it is the belt. If not keep looking.
    TacomaMike25[OP] likes this.
