18 Tacoma OR how fast on 4Hi
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jyeung90, Nov 21, 2024.
  1. Nov 21, 2024 at 10:41 AM
    Jyeung90
    Jyeung90 [OP] Active Member
    Josh
    2018 Toyota Tacoma TRD OR
    Driving on wet rainy roads notice I’ve been getting some slippage. Was wondering if I engage 4Hi how fast can I travel?
  2. Nov 21, 2024 at 10:42 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Any speed. The shifting into it has to be done below roughly 62 mph.
    Tocamo, musicisevil and Finn-2187 like this.
  3. Nov 21, 2024 at 10:45 AM
    Finn-2187
    Finn-2187 Well-Known Member
    2021 White Tacoma SR 4x4 DCSB
    Fog lights, Vision Turbine 16x8 wheels, Goodyear Wrangler Ultraterrain 265/75/r16 AT's, janky LEDs that probably won't catch on fire
    I'm addition, I'll say that I'd consider upgrading to better tires and/or adding some weight to the bed for traction before I'd consider running 4wd on rainy roads.
  4. Nov 21, 2024 at 10:48 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    No upper limit.
    But if you’re asking, I feel like I need to say that if you need 4Hi due to weather conditions, you should stay at a speed that allows you to maintain control of the vehicle
  5. Nov 21, 2024 at 10:49 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I think the fastest I’ve driven in four-wheel-drive high range is 50 to 60 miles an hour.
  6. Nov 21, 2024 at 10:52 AM
    musicisevil
    Alaska
    2019 TRD Sport
  7. Nov 21, 2024 at 1:09 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Sensible driving on wet roads in 4WD gains you nothing over 2WD - maneuvering and stopping ability really isn't appreciably better in 4WD.
    eurowner and RockBunny like this.
  8. Nov 21, 2024 at 1:13 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I do not recommend driving on pavement in 4wd wet or dry. You’ll understand why the first time you try to make a sharp turn.
    Chew, SGJarrod and 50Buck like this.
  9. Nov 21, 2024 at 1:28 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    If you feel the need to use 4 wheel drive on a wet paved road you are either going way too fast for conditions or your tires are worn out or otherwise unsuitable.
    STEELeR43, RockBunny, Chew and 2 others like this.
  10. Nov 21, 2024 at 3:43 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    You can do it, on the fly in "any" inclement weather. You'll just burn a heck of a lot more fuel this way on the Highway.
    Your owners manual is your friend. :evil:
    musicisevil likes this.
  11. Nov 21, 2024 at 8:10 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    maneuvering and stopping are actually worse in 4x4 due to drivetrain bind. abs and traction control system can no longer control each wheel individually as well as they could since front and rear are mechanically locked together. also naturally wants to understeer more.
  12. Nov 21, 2024 at 8:16 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Oooh
    Happy almost Friday.
    In 4lo… how fast can you drive?
    Or let’s say 2lo, if you’ve got that.
    I’ve got going about 30, and the whine is pronounced.
    but that’s the manual trans in the steep stuff
  13. Nov 22, 2024 at 10:08 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    New tires?
  14. Nov 22, 2024 at 10:39 AM
    OLDTRAP
    OLDTRAP Well-Known Member
    2021 TRD OR
    Stock
    If you are driving in a relatively straight line with no hard turns, slight veers are OK, you can drive perfectly fine in 4wd on dry pavement. Been doing it for 20+ years with zero issues.
  15. Nov 22, 2024 at 10:41 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    Accelerating, steering and braking. The three elements of car control.
    Guess which two are the most important and also aren't improved by deploying 4WD?
    If you cannot control your vehicle on a run-of-the-mill wet road. You're going too fast for conditions. End of story.
  16. Nov 22, 2024 at 10:53 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    Hey! its friday
  17. Nov 22, 2024 at 10:55 AM
    OLDTRAP
    2021 TRD OR
    Stock
  18. Nov 22, 2024 at 11:10 AM
    Buggin112
    Buggin112 Well-Known Member
    Portland, Oregon
    2022 Tacoma TRD Off-Road
    I do the same thing. I get a lot of wheel spin trying to get moving at stop lights. It isn't because of driving too fast. New tires as well. K02's were great on my old Explorer, not so much on my Tacoma.
  19. Nov 23, 2024 at 4:34 AM
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    You should probably drive to the conditions... but if you aren't, cruise control is pretty exciting on wet curvy roads.
