18' trd vacuum pump vs. Non vac pump motors???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Milemarker16, Mar 16, 2022.
  1. Dec 6, 2023 at 4:32 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    That is what I would have expected to have happen, lack of pressure to other camshaft-delivered oil pressure-dependent components, such as VVT. I'll look into it further when I have time.
    EDIT: After looking further, it appears I was originally correct, and there are no engines that have no pump and no ball. It's either pump or ball. It's just not extremely well documented, I dug a bit deeper and that is in fact the case.
    Jeff
    BLtheP[QUOTED] likes this.
  2. Dec 6, 2023 at 5:35 PM
    Kidneypunch
    Kidneypunch Member
    Ethan
    2021 TRD Sport
    My curiosity about the options here stem from the volume of the vacuum pump. It just kind of sounds like it is bad. Or something bad is happening. It seems to get Worse (louder) the more I drive throughout the day. The brakes work fine still. Once this thing starts to go though….If I could just shut it off and install an electric pump I’d be fine with that. At least then repair wouldn’t be a pain and it would probably cost a lot less.
    I suppose I am going to wait until it fails. This is a minor repair but the things it touches and downstream effects if done improperly……
  3. Dec 6, 2023 at 6:18 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    When you're at the point just use a brass punch to pile in the ball so nothing gets damaged. Don't use steel. I also don't recommend wood as it can splinter and find it's way somewhere bad
    Kidneypunch likes this.
  4. Jul 23, 2025 at 6:49 PM
    Darren/jonah
    Darren/jonah Member
    Darren
    16 Tacoma 3.5
    my truck has a vacuum pump engine with a bad cylinder. I bought a non-vacuum pump engine by mistake. Can I just swap the cam and vacuum pump out of my original engine into the new one?
  5. Jul 23, 2025 at 6:51 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    That should work just fine.
    Damn, feels like a lot of people dealing with engines lately.
  6. Jul 23, 2025 at 6:55 PM
    Darren/jonah
    Darren/jonah Member
    Darren
    16 Tacoma 3.5
    Other than the vacuum pump and the ball in the end of the cam are the two motors identical? Are all the cam sensors the same and stuff like that?
  7. Jul 23, 2025 at 6:59 PM
    BLtheP
    Plano, TX
    As far as I know those are the only differences. There are two versions of VVT actuators but supposedly they both plug in and function the same regardless. Not aware of any cam sensor differences. Even the cams themselves are the same, just one has the ball and the other does not.
  8. Jul 23, 2025 at 7:20 PM
    Darren/jonah
    Darren/jonah Member
    Darren
    16 Tacoma 3.5
    Would the VVT actuators be different if it was a manual or automatic transmission?
  9. Jul 23, 2025 at 7:21 PM
    BLtheP
    Plano, TX
    Not that I know of.
  10. Jul 23, 2025 at 7:23 PM
    Darren/jonah
    Darren/jonah Member
    Darren
    16 Tacoma 3.5
    on one motor the actuators have a large D after the part number on the other motor it’s a large c? Just trying to wrap my head around this. Thanks for the help
  11. Jul 23, 2025 at 7:25 PM
    BLtheP
    Plano, TX
    I’m not an expert on the differences between any of those but I recall them being mentioned as interchangeable and that there were two types. I would guess the different letter part numbers you are seeing are those different actuators. Still, as far as I know they are interchangeable. They look different behind the flange, visible once removed from the timing cover.
  12. Jul 23, 2025 at 7:54 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    its TRD Offroad and Pro, that have vacuum pump not just TRD
  13. Jul 23, 2025 at 9:35 PM
    joba27n
    Nolan
    Alberta
    I believe the offroad and pro had a hydro-brake booster for crawl control purposes and the other non-crawl control models were just vacuum pump equip.
    eurowner likes this.
  14. Jul 23, 2025 at 9:40 PM
    BLtheP
    Plano, TX
    Correct.
    TRD Off-Road & Pro - block-off plate and sealing ball installed in cam. Electronically operated hydraulic booster.
    All other trims - vacuum pump installed and no sealing ball in cam. Conventional vacuum booster.
    joba27n[QUOTED] likes this.
  15. Jul 24, 2025 at 12:00 AM
    #35
    Kidneypunch
    Kidneypunch Member
    Ethan
    2021 TRD Sport
    Yeah, you should be fine.
  16. Jul 24, 2025 at 9:11 AM
    #36
    Darren/jonah
    Darren/jonah Member
    Darren
    16 Tacoma 3.5
    Is there a way to swap out the cam without removing oil pans, and timing cover?
  17. Jul 24, 2025 at 9:26 AM
    #37
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Theoretically yes, if you can remove the tension from the chain and chain has enough slack.
    But I dont think the tensioner inspection cover is large enough to manipulate the tensioner.
    It requires some force to compress the tensioner.
    Also there is a risk to drop the chain and messed up the timing.
  18. Jul 24, 2025 at 9:51 AM
    #38
    Kidneypunch
    Kidneypunch Member
    Ethan
    2021 TRD Sport
    You can buy a new ball and install it without removing the cam.
  19. Jul 24, 2025 at 9:54 AM
    #39
    Kidneypunch
    Kidneypunch Member
    Ethan
    2021 TRD Sport
    All trims other than Off road and Pro have the hydraulic brake booster. All others have vacuum booster as I recall.
    SR, SR5 and TRD sport all have the vacuum booster.
  20. Jul 24, 2025 at 9:56 AM
    #40
    BLtheP
    Plano, TX
    Have you done that? Seems like there would be a risk of messing up the cam bearings…I’d think it requires a bit of hammering at least to get the ball installed.
