18" Wheel Question
Discussion in 'Wheels & Tires' started by Range 44, Nov 26, 2010.
  1. Nov 26, 2010 at 12:13 PM
    Range 44
    Range 44 [OP] Well-Known Member
    Georgia
    2008 FJ TTE
    What offset do I want on an 18X9 wheel to be flush with the fender. And what about with a 17X8?
  2. Nov 26, 2010 at 12:43 PM
    Range 44
    Georgia
    2008 FJ TTE
    Hub centric?
  3. Nov 26, 2010 at 12:57 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    My 18x9's have 5.4" backspacing and they sit out about 3/4" of an inch past the fenders with 265's.
  4. Nov 26, 2010 at 1:00 PM
    TexasTacoma37
    So that's a +10mm offset.
  5. Nov 26, 2010 at 1:03 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    if you go with a 9" wide wheel they are gonna stick out.
  6. Nov 26, 2010 at 1:31 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have 18x9"s on 285/65-18"s and they stick out about 1 inch past the fenders with a -12mm offset.
  7. Nov 28, 2010 at 12:53 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    This statement is incorrect, as it all depends on offset.
    I'm running 18x9's right now with 0 offset, and mine sit flush. You would need to run a negative offset in an 8" wide wheel to get flush (diameter doesn't matter, only width).
