$1880 King COs front&rear, Killer deal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomtn, Jul 14, 2011.
  1. Jul 14, 2011 at 10:51 PM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
  2. Jul 14, 2011 at 11:32 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    U first or second gen, the second gen kings from poly are 1800 fronts only and 2900 for the fronts and rears
  3. Jul 14, 2011 at 11:37 PM
    tacomtn
    I'm 2nd gen. It's $1880 parts# 25001-119 (front) and 25001-121 (rear).
  4. Jul 14, 2011 at 11:38 PM
    tbturner47
    tbturner47 Well-Known Member
    Travis
    Lenoir, NC
    '07 Indigo Ink Off Road
    Supercharger
    ^That's for the ones with the adjuster
  5. Jul 14, 2011 at 11:40 PM
    ExpoSpy
    ExpoSpy Well-Known Member
    Brian
    S.D.
    08 DCLB 4X4
    Those are for the Non-adjustable shocks. IMHO you should save up and go for the adjustable ones.
  6. Jul 15, 2011 at 12:00 AM
    tacomtn
    Adjustable compression is nice but I think for me, just getting high-end reservoir COs may be overkill already. I won't be doing any high-speed rallying or racing. But shucks, are they that much better on road than OMEs or Billies?
  7. Jul 15, 2011 at 7:14 AM
    Burgman
    Stephen
    Ric VA
    But ur comparing ext travel coilovers to stock replacement shocks, but if u were to get the nonadj kings u wouldnt need new ucas b/c ur not changing any suspension angles
    If i had 2k for my suspension i would go with the foxes at the current deal, both are top quality brands but ur getting much more suspension for ur money with the foxes
  8. Jul 15, 2011 at 8:21 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    x2
    I couldn't imagine paying $2000 without lifting it at all
  9. Jul 15, 2011 at 9:03 AM
    tacomtn
    You mean those Kings arent for lifting? Really? They not ext travel but still lift the truck up to 3" I read. They just dont have the extra downtravel, yes?
  10. Jul 15, 2011 at 9:15 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    no, no, no
    i will say it again, ALL race style coilovers (king, fox, Icon, SAW, radlfo) are adjustable in terms of the amount of pre-load you can put on the coil spring. the amount of preload on the spring determins lift height.
    the difference between the adjustable and non adjustable Kings is the compression/ damperning adjuster on the shocks resi. both the adjustable and non adjustable ARE able to lift the truck 0-2.5".
  11. Jul 15, 2011 at 9:19 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    having said that, there is a big difference between running a standard bolt in CO (king) and the LR UCA and the DSM UCA and ext length Fox CO
    the DMS package is a bolt on performance suspension, the extra travel is acheived from the uni ball style UCA and extra shock length... you will gain more wheel travel
    the bolt in CO and LR UCA will not yeild more travel, and the UCA only allows for more alignment, the stock ball joint is retained.
    IMO, the LR UCA and stock replacement CO is a waste of money for the benifits the kit yeilds. the DSM package is a much better buy
  12. Jul 15, 2011 at 11:15 PM
    tacomtn
    Ah, more downtravel specifically with the Fox Ext. Travel/DSM UCA vs. the standard travel King/LR UCA. Got it. Although the LR UCA uses its own ball joint, it's still a ball joint like the stock setup, and doesn't allow for ext. down travel.
    Sooo then, the Fox package is a much better value then the Kings. Thanks for the clarification. Now if only I can get some more cash together somewhere...
