18's who's got um?
Discussion in 'Wheels & Tires' started by FamouzStarz, Mar 10, 2008.
  1. Mar 10, 2008 at 11:13 AM
    FamouzStarz
    FamouzStarz [OP] The illest taco
    21 TRD PRO
    ICON Build and then some
    18's whos is running them and what are running rims/tires, lift or not?
  2. Mar 28, 2008 at 11:26 AM
    Rangerdirk
    Rangerdirk Active Member
    2005 Tacoma 4x4 6 in FabTech Lift
    6 inch FabTech Lift, 18 in Wheels, 325/65/R18,
    I'm running them right now. 325/65/18's on a 6 in Fabtech.
    Wishing i was running 17's these days, but i cant complain too much.
    Only problem i had was the front left tire going out of round and then in turn ruining the hub assembly and bearing.
    They would be much better if someone would come out with gears so that i could put them in. I cant find any gears anywhere for a 2005.
  3. Mar 29, 2008 at 9:12 AM
    iwc3714
    iwc3714 Well-Known Member
    PreRunner SR5
    Bull bar, oem side steps and 18" Enkei
    I'm running 18" enkeis.
    They were put on at the point on entry -Jacksonville FL.
    All I can tell you they are Michelin Cross Terrain 275/55/18. They run pretty smooth and don't rub.:)[​IMG]
  4. Mar 29, 2008 at 9:14 AM
    iwc3714
    PreRunner SR5
    btw, there isn't a lift. But one is coming in the near future.
  5. May 11, 2008 at 11:01 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Nice wheels!
  6. May 11, 2008 at 11:04 PM
    genxer36
    Sean
    Bethlehem,GA
    I've got 20" Einkes with BFGoodrich G-Force Low Profile tires on a stock 2005 Taco setup. Toyota Southeast Distributor installed them.
  7. May 12, 2008 at 4:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    18" Helo maxx 6 with Nitto TG's 285/60/18
  8. May 12, 2008 at 4:07 PM
    genxer36
    Sean
    Bethlehem,GA
    Nice Wheels! Do you get people stopping you & asking about your truck, like I do?
  9. May 12, 2008 at 4:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sometimes. :)
  10. May 12, 2008 at 4:45 PM
    05yota
    05yota Well-Known Member
    Beaufort SC
    05 Dbl Cab Long Bed
    Alpine IVA-W205 Double din TV, 10in Memphis shallow mount sub, Rockford Amp, 23in Akuza Bounce Rims!!!
    im running 23's with a stck set up and i only rub a tiny bit when backin up..
  11. Dec 30, 2011 at 10:43 PM
    Habujet
    Habujet Well-Known Member
    Dan
    SoCal
    11' SW SR5 DCSB
  12. Dec 31, 2011 at 7:43 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Wow what a thread revival.
