18watt pods not working as fog lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bassinbeam, Dec 25, 2017.
  1. Dec 25, 2017 at 11:01 AM
    Bassinbeam
    Bassinbeam [OP] Member
    Keiran
    2005 white Tacoma TRD
    i bought the cali raised bracket with the led pod kit to replace the stock fog lights. I have 18 watt 3x2 cali raised pods... It came with the oem plugs to make it much easier to wire. My fog lights work perfectly but then I installed the pods and they don't work.... what else do I need to do?
    Thanks in advance
  2. Dec 25, 2017 at 11:07 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Blow a fuse? I have the cali raised connectors butt connected together shoved up under my plate bumper. Both lights are about 14 watts. Check your fog fuse, highbeams arent on?
    Bassinbeam[OP] likes this.
  3. Dec 25, 2017 at 11:08 AM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Also try touching the positive and negative wires of the pods to some power and ground and see if they light up. Make sure they arent dead.
  4. Dec 25, 2017 at 12:26 PM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    I have read various members said that they had to reverse the wires to get the correct polarity.
  5. Dec 25, 2017 at 5:21 PM
    texasfight
    texasfight Well-Known Member
    Doug
    2009 Super White double cab TRD
    Rigid 32 in light bar, Back Rack, 265/75r16 General Grabber AT2's mounted on FJ Cruiser Trail Team wheels
    Switch wires they are reversed on the calis
