18x9 with 5" backspace
Discussion in 'Wheels & Tires' started by PipsTaco, Dec 15, 2013.
  1. Dec 15, 2013 at 2:15 PM
    PipsTaco
    PipsTaco [OP] Well-Known Member
    Jarrod
    Central Valley, Ca
    2020 TRD Off Road
    I plan on picking up a set of 18x9 fuel boost wheels with a 5 inch backspace and 285/60/18 terra grapplers. I plan on putting a toytec ultimate lift prior to running this wheel and tire combo, and more than likely new uca's. With the lift I still anticipate slight rubbing from what I have read. My question is, would a 4.5 inch backspace increase rubbing or decrease? I would rather have less wheel and tire sticking out which is why I decided on the 5 inch backspace. I may also try a 285/65/18 later on
  2. Dec 16, 2013 at 12:32 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    I ran this size wheel/tire combo at stock height with no rubbing, once the mud flaps were removed. With a lift, you should be able to run it without rubbing, even with the flaps still on. A 4.5" BS is going to increase rubbing.
  3. Dec 16, 2013 at 5:34 PM
    PipsTaco
    Jarrod
    Central Valley, Ca
    2020 TRD Off Road
    thanks for the reply…that is what I was hoping to hear!!
