18x9's on an '01 dbl cab...possible?
Discussion in 'Wheels & Tires' started by ebayollis, Mar 9, 2012.
  1. Mar 9, 2012 at 7:21 AM
    ebayollis
    ebayollis [OP] MY DIXIE WRECKED
    josh
    spruce pine nc
    2017 tacoma trd sport ddbl cab 4wd auto
    I have a 2001 trd dbl cab taco with no lift...stock suspension...I found a great deal on some 18x9 wheels and was wondering if they would fit? I'm not sure of the backspacing. What back spacing would be ideal? Also if these will fit, what size tires would you recommend? Thanks!
  2. Mar 9, 2012 at 11:52 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    for a first gen you would want around 4.0 to 4.5" backspacing, and you can run 265/65/18's with no lift. Check the tire manufacturers site though because some brands of 265's aren't approve for use with 9" wide wheel.
  3. Mar 9, 2012 at 2:59 PM
    ebayollis
    josh
    spruce pine nc
    the wheels i wanna get are ballistic jester 18x9 with 5.5 backspacing...would these work...or would i need to get wheel spacers?
  4. Mar 10, 2012 at 6:55 AM
    KPT
    09 Prerunner
    5.5" is too much, they will sit in 1" closer to the uca than your stock wheels
  5. Mar 10, 2012 at 9:57 AM
    ebayollis
    josh
    spruce pine nc
    Not to sound like Noob but what's a UCA?
    Couldn't I just putt a spacer behind it to counter act this?
  6. Mar 15, 2012 at 2:41 PM
    KPT
    09 Prerunner
    Uca is upper control arm. You could use a spacer but why not just buy the proper wheels to begin with?
