'19 Taco wont start unless brakes are pumped
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GBB777, Dec 15, 2022.
  1. Dec 15, 2022 at 12:49 PM
    GBB777
    GBB777 [OP] Member
    Sold my 2019 basic 2WD automatic SR truck, with only 2,500 miles on it, to a friend a few months ago. I bought it new and never had a problem with it. My friend just called to say he's always had problems with it starting unless he pumps the brakes first, and that the other day, it wouldn't start at all and he had to get a jump start from a neighbor. To me it sounds like the battery, but I find it odd that pumping the brakes would help get it started. Anyone ever had a problem like that?
  2. Dec 15, 2022 at 1:11 PM
    Tacospike
    Two Trucks
    Is it a push to start?
  3. Dec 15, 2022 at 1:49 PM
    GBB777
    GBB777 [OP] Member
    No, it's just a basic bottom of the line 2019 SR truck.
  4. Dec 15, 2022 at 1:51 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Auto or Manual?
  5. Dec 15, 2022 at 1:54 PM
    GBB777
    GBB777 [OP] Member
  6. Dec 15, 2022 at 1:57 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    mmm...well i know my truck will crank without pushing the brake
  7. Dec 15, 2022 at 2:01 PM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    Low / bad batteries make these truck do weird things! Change the battery and it should be good. Stock batteries suck!
    Rusty66 and TexasWhiteIce like this.
  8. Dec 15, 2022 at 2:04 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    This 100%
    It’s a 2019, and a lot of batteries need to be changed every 3 years depending on environment and driving habits.
  9. Dec 15, 2022 at 2:05 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Don’t understand why I keep on seeing this. What’s wrong with stock batteries? Do you have a source that supports this?
  10. Dec 15, 2022 at 2:12 PM
    513Mugsy
    Cincy
    No source, just personal experience. Have had three of these trucks now.
    2016 bought it 1 1/2 yrs old. Needed a battery within 2 months...making that stock one no more than 2 yrs old.
    2021 new truck off the lot on lease. Battery died in the middle of August, 8 months old. It was dead, truck was stock. Making that stock battery no more than 1 1/2 yrs old.
    2020 used truck ...From Canada with only 7800 miles. Been in service since new for 1 yr 1 month per OG owners notes and receipts before it was changed to a die-hard battery. So that one was no more than 1 1/2 yrs old also.
    So I guess your on the stock battery still? If so I guess you got a good one.
    wilcam47 and Junkhead[QUOTED] like this.
  11. Dec 15, 2022 at 2:13 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i've never had to replace an OEM toyota battery in any of my toyota vehicles. even ones that were over 6 years old. maybe i got lucky?
    one time i had to clean the terminals and another time i had to charge it with a trickle charger but that was my own fault.
    Junkhead[QUOTED] likes this.
  12. Dec 15, 2022 at 2:15 PM
    snapspinner
    snapspinner Well-Known Member
    Shawn
    2023 TRD OD DCSB Electric Lime
    Yeah, if it starts OK when jumped I'd look at the battery first. Not sure about the pumping the brakes thing? Might be 2 separate problems? Try swapping batteries first and see how it goes.
    wilcam47, Junkhead and Chew like this.
  13. Dec 15, 2022 at 2:29 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Wow that’s crazy. I’m still rocking original battery and my truck sits outside 5 days a week with no tender.
    FWIW OEM battery on my dads 2013 4R lasted 8 years.
  14. Dec 15, 2022 at 2:30 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    My 2009 OEM Battery lasted 8 1/2 years to
  15. Dec 15, 2022 at 2:31 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I cleaned terminals once and sprayed some red anti corrosion spray on them. Been great so far, curious how long my OEM battery will last. Truck still starts just fine.
    cryptolime[QUOTED] and HondaGM like this.
  16. Dec 15, 2022 at 2:32 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Not sure why some folks have such shitty luck.
    Maybe leaving interior lights on? Playing music a lot with engine off? Short trips?
    HondaGM[QUOTED] likes this.
  17. Dec 15, 2022 at 2:36 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    not positive but I think there is a safety switch on the brake pedal that is part of the start system (ignition) - if the switch goes bad or is stuck in the wrong position it will prevent you from starting the vehicle. I think it is located up under the cover below the steering wheel - follow the brake pedal arm up under the cover - you should be able to see it and inspect it to see if it is gummed up and not working properly when the pedal is pressed and released.
    HondaGM and Kolache007 like this.
  18. Dec 15, 2022 at 2:41 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    try moving the shifter?
  19. Dec 15, 2022 at 4:07 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Short duration trips perhaps? Not enough drive time to fully charge the battery.
    HondaGM and Junkhead[QUOTED] like this.
  20. Dec 15, 2022 at 4:09 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    This thread needs Pumping…
    hiPSI and bishtaco like this.
