'19 Taco wont start unless brakes are pumped
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GBB777, Dec 15, 2022.
  1. Dec 15, 2022 at 4:11 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Hm maybe. Since my truck doesn’t get driven 5 days a week, I make sure to take it for a nice 30-40 min highway drive on the weekends. Also, my interior lights are always in OFF position. I do listen to music with the truck off quite often though.
    HondaGM and cryptolime like this.
  2. Dec 15, 2022 at 4:18 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Environment means a lot. Really hot reduces life. Really cold reduces life. How long a battery has been manufactured before install means life.
    HondaGM, erok81 and Canadian Caber like this.
  3. Dec 15, 2022 at 4:26 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    before replacing the battery try fully charging it, with a battery tender, and verify the voltage at full charge. Ski
    HondaGM and FishaRnekEd like this.
  4. Dec 15, 2022 at 4:28 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Mine went bad, just under two years old.
    HondaGM likes this.
  5. Dec 15, 2022 at 6:01 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I’m pretty sure I have to press brake to start truck. Mines a 2017 Sport automatic.
    HondaGM likes this.
  6. Dec 15, 2022 at 6:07 PM
    erok81
    erok81 Well-Known Member
    Imposter
    I didn’t do any of that any mine died around 10-15k miles.
    hiPSI and HondaGM like this.
  7. Dec 15, 2022 at 6:17 PM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    I had an optima gold top 1k cranking amp battery for over a decade before it finally shit the bed permanently.
    HondaGM likes this.
  8. Dec 16, 2022 at 12:24 AM
    Sasquatchian
    Sasquatchian Well-Known Member
    The first battery in my 2018 OR DCLB lasted 2-1/2 years and them boom. No warning signs of slow cranking. Just dead. And of course I had cleaned all the terminal connections on a regular basis since new. The second battery, a Bosch from Pep Boys went exactly one year but since Pep Boys got bought out by Advanced Auto, the warranty was not honored. So far so good on the third battery after a year. Here in Los Angeles I typically get 4-5 years, or at least I have in the past.
  9. Dec 16, 2022 at 9:06 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    nearly 4 YO truck with less than 3k?
    Yeah, unless you put that on a battery tender, I would be suspecting, testing, and charging the battery,,,, know full well, I am most likely going to have to replace it.
  10. Dec 16, 2022 at 9:08 AM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    made in japan battery on your dads 4runner. My 2006 4runner and 2014 Fj oem panasonic batteries lasted 10 years both made in japan. My taco and tundra both only lasted 2 years.
  11. Dec 16, 2022 at 12:52 PM
    jjsinaz
    jjsinaz Well-Known Member
    Jim
    Sun City West, AZ
    2023 TRD Sport DCLB Ice Cap 4X4
    If this continues after replacing the battery, I'd start looking at all of the ground connections. Anytime I've had a wierd electrical problem, it's usually turned out to be a bad ground.
  12. Dec 16, 2022 at 1:49 PM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    One more data point, the OEM battery in my 20 OR lasted 2 years & one month. Replaced with a Northstar AGM so we’ll see how it goes
  13. Dec 16, 2022 at 2:15 PM
    perterra
    perterra Well-Known Member
    Tejas
    Never seen the gold top, my red top lasted about 3 months before it died. They replaced it under Optima warranty, the replacement died within six months, I replaced it with a Walmart Everstart, it was still working fine when I sold the Xterra 2 years later.
  14. Dec 16, 2022 at 3:59 PM
    mbigpops
    mbigpops Well-Known Member
    2017 TRD Sport
    Another hijacked post by battery whiners. What a shame.
    Get a battery tester and test your battery. Checking the voltage is not the whole story.
    Battery testers are not expensive and tell you the health of your battery and even the charging system.
    If your battery tests okay then it is probably the brake switch as suggested.
    Also, never sell a vehicle to friend - especially one who calls you with a problem after they buy it.
    GBB777[OP] and Chew like this.
  15. Dec 17, 2022 at 8:15 AM
    #35
    FishaRnekEd
    New Orleans, LA
    Gold top is AGM deep cycle.
    It can be fully discharged a few times and still come back to life.
    Red top is not deep cycle. Kill it once and it's probably dead, dead
    The 4.0 v6 needs about 700 cranking amps.
    I always get a battery with more than required. Gives wiggle room if the weather gets freezing or blazing
  16. Apr 2, 2023 at 4:00 PM
    #36
    GBB777
    GBB777 [OP] Member
    UPDATE buyer is still complaining car doesn't always start the first time. Had battery checked and was told it's fine. Took it to his mechanic who now says it needs a new starter. Truck only has 4,000 miles on it. I'm skeptical but do hope that replacing the starter takes care of the problem. I'll post again if that was the fix.
  17. Apr 2, 2023 at 4:03 PM
    #37
    Chew
    Chewy
    Midwest
    19 TRD OR
    If it’s the original battery, you’ve got nothing to loose by trying, as it’s on borrowed time anyways.
    Again, low mileage (use) is hard on a battery.
  18. Apr 2, 2023 at 4:05 PM
    #38
    GBB777
    GBB777 [OP] Member
    Battery tested fine. They're going to replace the starter, not the battery.
  19. Apr 2, 2023 at 4:18 PM
    #39
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    A 4 year old truck with only 2500 miles? Where did u store it? Is it possible some rodent damage occured?
  20. Apr 2, 2023 at 4:20 PM
    #40
    Chew
    Chewy
    Midwest
    19 TRD OR
    Gotcha, makes sense. I mean if you’re going to guess at it, start with the most expensive, least likely to fail part and work your way back.
