1911 BS thread
Discussion in 'Guns & Hunting' started by WhatThePho?, Jan 8, 2015.
  1. Feb 19, 2020 at 1:47 PM
    #1181
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Installed. Pretty happy with these.
    p1smo, Tom0662, RickS and 6 others like this.
  2. Feb 19, 2020 at 1:51 PM
    #1182
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    That looks clean!
  3. Feb 19, 2020 at 2:20 PM
    #1183
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    sexy
  4. Feb 19, 2020 at 2:27 PM
    #1184
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Thanks!
  5. Feb 19, 2020 at 2:28 PM
    #1185
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Thanks!
  6. Feb 19, 2020 at 4:16 PM
    #1186
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    No before pic!!!
    Disallowed
  7. Feb 19, 2020 at 4:21 PM
    #1187
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    You just want gratuitous 1911 shots.
    Perv.
  8. Feb 19, 2020 at 4:31 PM
    #1188
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
  9. Feb 19, 2020 at 4:40 PM
    #1189
    Superhulk LB
    Josh
    Oregon
    Those grips transform the look.
    Tom0662 likes this.
  10. Feb 19, 2020 at 9:20 PM
    #1190
    Old Marine Cal
    2015 MGM DBLCAB
    From reasonably cool
    To simply BADASS
    Doughnut Spaghetti likes this.
  11. Feb 20, 2020 at 3:03 AM
    #1191
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Thanks
  12. Mar 14, 2020 at 9:50 PM
    #1192
    Superhulk LB
    Josh
    Oregon
    What do you guys recommend for a good 1911 oil/lube? I took my Springfield out today and it would cycle. It was about 29 degrees out and I don’t think I’ve cleaned it the last couple times I’ve shot. But would have expected it to be okay for more than 50-100 rounds between cleaning. And tips?
  13. Mar 15, 2020 at 3:34 AM
    #1193
    GPC
    GPC Well-Known Member
    LFOD
    2015 Tacoma TRD Pro
    I use SEAL-1 CLP works great in all temps my go to lube for all weapons. I've done 1k round test for articles and SEAL-1 has never failed me.
  14. Mar 15, 2020 at 5:47 AM
    #1194
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    You should definitely get more than 100 rnds
    I’ve used all sorts of gun lubes, lately I’ve been running on the ALG Go-juice. Are you running the gun wet? Wet attracts powder leavings and turns into gack paste like chit.
    A thin film is all I’ve ever used. When lubing the gun I use a couple drops on the swing link, use my finger to wipe the ramps that the slide release rides on also wipe the lock up lugs. I put a couple drops on the rails of the lower frame and spread with my finger then wipe the end of the barrel where it locks up in the bushing. Finish assembly, rack it a few times and take it out to the range n drive it like yah stole it.
    By the way my gun has +50K rnds through it
    The manual is a bit dated but the M&M manual will show you everything thing you need to know about field stripping or detail stripping the 1911
    RickS and Superhulk LB[QUOTED] like this.
  15. Mar 15, 2020 at 6:07 AM
    #1195
    Superhulk LB
    Josh
    Oregon
    Honestly,I can’t remember how I cleaned it last time. I’m still new to 1911s and not as good as cleaning and caring for firearms as I should. I normally just wiped the firearms down with a silicone cleaning cloth to prevent rust and then put them away. I think I only used a little oil on a few contact points last times I fully cleaned and lubed it. I’ll have to pay more attention.
  16. Mar 15, 2020 at 6:13 AM
    #1196
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    Someone at the shop where you bought it should be able to show you how to field strip your 1911 and actually that goes for any gun you buy.
    Superhulk LB[QUOTED] and JimBeam like this.
  17. Mar 15, 2020 at 6:21 AM
    #1197
    HeyWannaTaco
    HeyWannaTaco Well-Known Member
    Dan
    Ontario
    2019 Red DCLB SR5
    OVTuned, OKX Skids, AVS In-Channel, N-fab Predators
    Try shooting it with almost no lube when it's cold. Or use a dry lube. My Beretta was slowed down so much in the cold there was a pause in the cycling process, same with my 1911. I clean and dry day before a match, use a lightly damp cloth with clp, or dry teflon lube and usually good to go.
    Any oil seems to just get very thick and slows things down, like in a cold engine.
    Superhulk LB[QUOTED] likes this.
  18. Mar 15, 2020 at 6:22 AM
    #1198
    Superhulk LB
    Josh
    Oregon
    I’ve been thinking about this more. And I’m guessing last time I cleaned it, I was watching the YouTube from Mrgunsngear where he strips it and recommends how to clean it. I likely used the oil provided with the gun.
    P2W[QUOTED] likes this.
  19. Mar 15, 2020 at 6:28 AM
    #1199
    HeyWannaTaco
    Dan
    Ontario
    2019 Red DCLB SR5
    My STI Trojan 9mm.
    rybern, CaptAmerica, RickS and 3 others like this.
  20. Mar 15, 2020 at 6:36 AM
    #1200
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    I like the 9mms as well
    RickS and Old Marine Cal like this.
