195,000 Miles---What Oil?
Discussion in '1st Gen. Tacomas (1995-2004)' started by gatrapper, Nov 4, 2011.
  1. Nov 4, 2011 at 6:43 AM
    gatrapper
    gatrapper [OP] Well-Known Member
    CJ
    Senoia, Georgia
    1998 SR5 4x4
    Hey Y'all,
    My 98 has 195,000 miles. I have always just had the generic oil from the shop put in there when I took it to have the oil changed.
    Im going to start changing the oil myself and want to use the good stuff.
    Was thinking maybe a 5W-30--synthetic or not?
    I have heard that using synthetic on a high milage engine like mine that has never used the stuff may not be good.
    Thoughts?
  2. Nov 4, 2011 at 6:51 AM
    krap22
    krap22 Well-Known Member
    pick a brand and stick with it, keep changing the oil at the maintenance schedule, drive the hell out of it
    I used the normal quaker state on my '99 and it was running flawlessly at 196,000. My Honda CRX went to 225,000 on normal quaker state with regular oil changes. The most important thing is that you change it regularly.
  3. Nov 4, 2011 at 6:57 AM
    resq330
    resq330 El' Capi-Tan
    Josh
    VA
    13 MGM DCSB TRD-Sport
    K&N Drop-In, Dick Cepek 'Torque' Wheels, Wet Okole Seat Covers, LED Interior
    Last oil change on my Honda Accord it had 231,000 on it. The service guy recommended going with a 30 weight oil. I did and mine is still running great.
  4. Nov 4, 2011 at 7:02 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    With that many miles.....I would not go with synthetic.
    Synthetics tend to act as cleaning agents and helps remove sludge (so to speak). Using synthetics now - may cause new leaks to develop.
    I switched to synthetic on my 96 with 60K miles and I developed a leak down at the oil pan and a slight lifter tap after owning it a couple years.
  5. Nov 4, 2011 at 7:02 AM
    racerxtaco
    racerxtaco Well-Known Member
    Joey
    virginia
    01 xtra-cab 4X4 w/cap
    stay with whats working for you, and it seems like faithful regular oil changes with conventional is the way to go. keep up the good work and your truck will reward you with many more years of reliability.
  6. Nov 4, 2011 at 8:16 AM
    TallTacoma
    TallTacoma Bear fvcker!
    Charles
    The Silver State
    Come and take it from my cold, dead hands.
    3" suspension lift (ToyTec coilovers and wheeler leafs), Yakima roof rack, ARE tonneau, K&N FIPK.
    I concur, Doctor.
  7. Nov 4, 2011 at 9:39 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    this is a well spread myth, and is not true.
    Synthetics do not create leaks, but will show a bad seal sooner than dino oil because the molecules in synthetic are smaller and will creep their way through an infant leak quicker than dino oil. There are no detergents in synthetic that will eat away at your seals. The seal was already going bad and the synthetic is just "pointing it out" quicker, it would eventually leak with dino oil too.
    I switched to synthetic at 160k miles and have had no problems so far and I am at 175k miles.
    OP: My recommendation is to start using synthetic, but whatever oil you use (dino or synthetic) make sure you change it at regular intervals and use a good paper air filter to keep your oil clean.
    I believe 5w30 oil is what is recommended for our trucks.
    Avoid fram and STP oil filters (Use OEM oil filters and air filters, best option IMO)
    My favorite dino oil is castrol, favorite synthetic is mobile 1 or castrol. And I either use a mobile1/K&N oil filter or an OEM toyota oil filter.
  8. Nov 4, 2011 at 10:13 AM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Sounds like you got 195K from your engine without a major problem - maybe we should be asking YOU what oil to use :rolleyes:
  9. Nov 4, 2011 at 11:29 AM
    gatrapper
    CJ
    Senoia, Georgia
    1998 SR5 4x4
    Alright y'all guess I will stick with what I have been using. Never have had a single problem with the truck *knock on wood* so I won't change now.
  10. Nov 4, 2011 at 1:31 PM
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    OME Nitrocharger OME Dakars All the other small goodies
    I have using Fram and Mobile one synthetic for 172k miles.... zero problems man
  11. Nov 4, 2011 at 1:41 PM
    marcchrisv
    marcchrisv Well-Known Member
    Gardnerville, NV
    99 Tacoma xtra, 2.7
    Toytec 2.5" lift., just the beginning. Front Builstein coil-overs fully adjustable from 0-3". 2" AAL in the rear with 2.5 degree shim. Total Chaos uni-ball UCA's.
    if you switch to synth you have to forever use synth.. also, due to the slightly lower viscosity of the synth oil and higher detergent cleaining level you might find leaks. I've been running synth in my truck since 99K (now at 236K) and never had a problem though.
  12. Nov 4, 2011 at 1:42 PM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    Chevron Delo 400, in everything I own. If it keeps big diesels on the road for 100,000 miles between oil changes, it should be good in my cars for 5,000 miles.
    I have been using it for over 20 years and zero engine problems.
  13. Nov 4, 2011 at 3:07 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Have heard the same thing about SWITCHING to SYN--I would stay w\what you have been using. Ran havolin 10-40--in my 91- 4 banger-200k miles--never a problem.
    Gone but not forgotten--miss that truck SOLD IT--running GREAT.
  14. Nov 4, 2011 at 5:21 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    Your engine was designed for regular oil, stick with it.
  15. Nov 4, 2011 at 5:36 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    This is also a popular myth that is not true. But with that many miles on the engine already, why switch?
  16. Nov 4, 2011 at 5:41 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    ive got 190,000 on my engine now and get the oil changes at Toyota using their oil which is Mobile1. The guys at Toyota were taking bets on how far my engine will go on the regular maintenece schedule I have my truck on, they all believe it will easily go 300,000!
    Gotta love Toyota quality
  17. Nov 4, 2011 at 6:48 PM
    hulkit
    hulkit Well-Known Member
    sacramento ca
    2000 tacoma 2.4l automatic
    not too long ago i just did some maintenance on my truck
    lets see i did trans dex3 with filter
    changed my differential with synthetic 75w90
    and changed from normal 5w30 to synth 5w30
    if your going to change to synth i would recommend doing the 5oz seafoam in the oilpan
    btw i did that around october 16 at 296678 Miles
    and as of now its been running in my system for about 2k miles and running great
    always check my fluid levels and my pan under my truck no leaks as of yet so ya im running it on high miles and havnt had any problems and have actually seen some increase in MPG by doing all of it
    hope this helps
  18. Nov 5, 2011 at 9:36 PM
    300k96Tacoma
    300k96Tacoma Well-Known Member
    Weaverville NC
    96 Reg. cab 4x4 Tacoma
    Stock-300k miles
    My truck has 307k on it now its a 96, I have been using mobil 1 super 5w30 high mileage conventional oil for awhile now and I think its a good oil to use. There aren't many 5w30 high mileage oils and I feel mobil 1 is the best but like others have said, use what has been working for you!
  19. Nov 6, 2011 at 4:55 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Keep doing what you have been doing. If it works why change?
  20. Nov 6, 2011 at 5:01 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    over 260k on mine and i use royal purple full synthetic
