1978 Ski Nautique Problem
Discussion in 'Boating & Fishing' started by dwalden2, Jun 2, 2011.
  1. Jun 4, 2011 at 9:26 PM
    dwalden2
    dwalden2 [OP] HBTFD
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, 285/70/17 STT Pros, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    I agree. I've thought that from the beginning. I'll update ya when they get it figured out. Everyone was busy today so I don't know if anything got done to it.
  2. Jun 5, 2011 at 10:51 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Ignition modules sometimes fail only when hot.
  3. Jun 5, 2011 at 10:58 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    ya now i think of it. my old coil on my boat used to heat up and quit working.
  4. Jun 6, 2011 at 3:54 PM
    dwalden2
    dwalden2 [OP] HBTFD
    Derick
    Blue Ridge, Georgia
    Yea I thought of that a few days ago. They replaced the coil and nothin changed. I went over there yesterday and hung out for a while. They've got everything out of the boat and they repacked some bearings and stuff while they had everything open. They rode around in front of the dock for a few minutes and right out of the gate it wasn't running right. We messed around with some stuff and nothin was helping, and then some people showed up and we gave up for the day. A little later I was sitting on the pontoon and smelled gas really strong. I was layin above the gas time on the pontoon and everyone thought I was just smelling it from there. A couple minutes later we went over and looked at the ski boat and there was gas coming out the bottom of the fuel filter. That explains why there was gas coming out the bilge pump a few days ago. Took out the pump and there was a REALLY tiny hole in the bottom. It wasn't leaking before they took it out earlier in the day. I don't know why it just randomly started. I had to work today but they were changing the filter and running some SeaFoam through it. I havne't heard if it made any difference or not yet...
  5. Jun 6, 2011 at 3:55 PM
    dwalden2
    dwalden2 [OP] HBTFD
    Derick
    Blue Ridge, Georgia
    The boat giving the problems...
  6. Jun 7, 2011 at 4:01 AM
    maxboi
    maxboi MAXBOI
    Brian
    SODA CITY
    2011 White D'Cab OR 4wd
    76 FJ horns, Weathertechs, Backup Camera anytime switch, Fogs anytime, Clamp & Washer tailgate, Diff Breather,
    I had a Glastron do something similiar a long time ago. This sounds like a clogged carb, does ok till warm them problems may indicate it's ok when partially choked. So idle or slow circuit may be clogged.
    Back to the Glastron. I couldn't figure it out and neither could the dealer. An old friend happened to appear when we had the boat in the test tank and said swap the condenser. Bingo.... always kept a spare in the glove box.
    $.02
  7. Jun 8, 2011 at 6:54 PM
    dwalden2
    dwalden2 [OP] HBTFD
    Derick
    Blue Ridge, Georgia
    No updates today. I haven't talked to them today to see what's goin on. I'm assumin it's not workin because if it was they would text me and let me know.
  8. Jun 8, 2011 at 6:56 PM
    TacoMatt02
    TacoMatt02 Well-Known Member
    South Carolina
    02 sr5 double cab
    I'll tell you what the problem is, its a boat and its 33 years old :p. My 2010 Scout has given me problems and it only has 20 hours on it.
  9. Jun 8, 2011 at 6:58 PM
    dwalden2
    dwalden2 [OP] HBTFD
    Derick
    Blue Ridge, Georgia
    Haha. Yea...that's what we keep saying. It's a boat...they all have problems.
  10. Jun 8, 2011 at 7:00 PM
    TacoMatt02
    South Carolina
    02 sr5 double cab
    found out that it was actually the ethanol gasoline i was using. My motor was sputtering at idle. Flushed engine, changed gasoline flows like a charm.
    but needless to say I've had many boats, and the problems will keep coming
  11. Jun 8, 2011 at 7:04 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    try posing your question in iboats.com.
  12. Jun 8, 2011 at 7:58 PM
    1bad10tacoma
    1bad10tacoma Well-Known Member
    Mark
    Brewer Maine
    2025 dcsb Trd off-road
    tonneau,
    Sounds like a fuel issue.The ethanol in the gas has been causing a lot of problems here. I had this problem last year in mine. I drained the carbs and the fuel tank and it took care of it.
  13. Jun 8, 2011 at 8:09 PM
    dwalden2
    dwalden2 [OP] HBTFD
    Derick
    Blue Ridge, Georgia
    Yea, we've got one place around here that doesn't have ethanol in their gas supposedly. They've ran ethanol free for the last 3 tanks and have ran seafoam to try to clean everything up a little.
    Thanks. I may try that if they can't get it fixed in the next day or so.
  14. Jun 8, 2011 at 8:24 PM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    If the boat has fiberglass tanks and gas with ethanol sat in them all winter the tanks are most likely coming apart. Fiberglass and ethanol DON'T go well together. Also after sittin all winter the ethanol seperated from the "gas" and compounded the problem by having pure alcohol at the bottom of the tank.... Just my guess on the problem.....
    There have been a few boats in my local marina that sank because the ethanol ate thru the tanks and right out the bottom of the boat.
    Put a new fuel pump in it and a new filter and then run the boat out of a 5 gallon can for a test run........
  15. Jun 15, 2011 at 5:36 AM
    #35
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    Yes, ethanol will destroy the fuel system on a boat of that vintage. Another thing to look at....
    Some fuel systems have check balls in the filler lines. These too will corrode and stick which will lead to a fuel starvation issue. you say this occurs after approx 30mins which is enough for a mechanical pump to draw a sizeable vaccuum on the tank. So check the tank vent lines and see if a filler check ball is seizing up.
    Good luck, it's a nice looking boat.
  16. Jun 15, 2011 at 6:08 PM
    #36
    dwalden2
    dwalden2 [OP] HBTFD
    Derick
    Blue Ridge, Georgia
    Thanks.
    It's been rainin and stuff so they haven't even been workin on the boat, so I don't have any updates. I'll let ya know what we get figured out, though. I know they've got a fuel pump on order. They might have picked it up today. Not sure.
  17. Jun 24, 2011 at 9:17 PM
    #37
    dwalden2
    dwalden2 [OP] HBTFD
    Derick
    Blue Ridge, Georgia
    Well I've been waiting on bad news before I posted, but so far, I don't have any. They finally replaced the fuel pump (like I said to do in the first place), and she seems to be runnin fine. It's rained a lot, so we haven't gotten to run it much, but we ran it pretty hard and then I wakeboarded for a bit and it was runnin strong. Might have finally gotten it figured out!
  18. Jun 24, 2011 at 9:25 PM
    #38
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    i hope the pump was the problem because its no fun when the boats on the trailer.
  19. Jun 25, 2011 at 8:52 AM
    #39
    dwalden2
    dwalden2 [OP] HBTFD
    Derick
    Blue Ridge, Georgia
    That's for sure.
    Haha. I said the same thing. My girlfriend even told her brother "Derick's been saying that was the problem since you started working on it."
  20. Dec 15, 2019 at 7:15 AM
    #40
    Slonis888
    Slonis888 New Member
    Scott
    Formula & Winner
    Replaced freeze plug
    I had a similar problem, it showed up mostly in turns on a Formula with V8 I/O ON TURNS!!! Check the FLOAT SETTING! When boat is level like just starting if level is set too low it will still seem great, afterwards when tilting from turns or hole shot low level in gloat chamber will cause your symptons...
    TacomaJunkie8691 likes this.
