1980-1989 Toyota pickup images please!
Discussion in 'Toyota Trucks & SUVs' started by ComaChic, Jan 26, 2010.
  1. Jan 31, 2011 at 10:19 PM
    #81
    Nine Mile Style
    Nine Mile Style Big Cat
    PNW
    05 Tacoma trd offroad and an 85 4x4 pickup
    Flowmaster super 40 k&n cai
  2. Feb 1, 2011 at 4:44 PM
    #82
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    :eek: Awesome! How many miles are on it?
  3. Feb 1, 2011 at 5:11 PM
    #83
    WheelTired
    WheelTired Well-Known Member
    Noth Colorado
    S-Runner
    Awesome 81, looks like new !!
    here are the specs on my 83 above, I will be selling it soon...it has been replaced by a bigger rig.
    Engine
    Professional built Chevy V-8 small block 400 Stroked (6.7 Liter) with only 14K miles. Rods are longer than stock at 6-inch length. Edelbrock Pro-Flow Multi-Port Sequential Fuel Injection has keypad in cab for adjustments on the fly. Trick Flo aluminum cylinder heads. Custom Erson cam shaft. Roller lifters and roller rocker arms. Evans waterless NPG+ coolant with total bypass thermostat. Power Steering. Air Conditioning. R & M heat exchanger hot water shower system. Premier Power welder and power supply with 160 AMP alternator, Cilton High Torque Starter … . Engine temperature runs cool.
    Transmission and running gear
    NV-4500 5-speed manual transmission with 0.75 overdrive and 5.61:1 first gear. Dual Toyota transfer cases with two shifters, front input shaft heavier 23 splined for torque. J. P. Eater adapter and 2.28:1 gears front case, 4.1:1 gears rear case. Final crawl ratio is 215:1. Dana 60 rear axle, Moser 1.5 inch 35 spline axles. 4.10:1 Dana gears, ARB air locker, Rear disc brakes with E brake, Long traction bars allow for articulation. Toyota stock front axle with Tru-Trac gear proportional locker, disc brake upgrade with Land Cruiser vented rotors and 4-Runner big caliper disc brakes. Toyota Land Cruiser brake master cylinder and clutch master cylinder. Custom-made National Springs on all 4 corners. Rancho 9000 5-way adjustable shocks. Front and rear sway bars with disconnects. Tires are BF Goodrich 33x12.5x15, Spare is 33x9.50x15. Firestone Ride-Rite air compressor and small tank with pressure regulator to supply ARB locker and to air up tires.
    Miscellaneous
    Renuel custom made front bumper ¼-inch steel and ½-inch mounting. Warn 8000-pound winch with dash control switch. Hella Rallye 4000 mounted on bumper, right Corning, left Euro driving. Hella fog lights mounted within bumper. Hella twin trumpet air horn mounted under bumper. Renuel rear bumper ¼-inch steel and ½-inch mounting. Custom rock skids to protect body between tires. Stock 16 gallon gas tank and 13.5-gallon gravity flow to main tank under the spare tire. Audiovox Electronic Cruise Control. Hand throttle on transmission shifter. Diamond Liner spray in bed liner.
    2001 Four Wheel Pop-Up Ranger Model
    Ranger model is 8 foot long and sized for pickups with 17-inch height side bed rails.
    Camper features
    3-Way Refrigerator. 16,000-BTU forced air furnace. 8-foot Fiamma awning. Side awning and back porch lights. Front sliding window. Deadbolt. Arctic Pack insulated liner. 2 roof vents. Front roof vent Fan-Tastic power vent. Shurflo water pump and faucet. 2 burner stove top with cover. 20 lb. LP gas tank with gauge. 12-gallon water tank. Slide out Queen-sized bed. Hella map lights in upper bed. Storage closet. Cable jacks free standing. Camper battery mounted in truck bed. Electronic interior water and battery meter. Wired LED DC volt meter. 300 watt power inverter. Camper outside bottom wood is well-protected with 3 coats of polyurethane floor enamel.
  4. Feb 2, 2011 at 8:29 AM
    #84
    Ninja14
    Ninja14 Well-Known Member
    Arkansas
    02 Tacoma DC 4x4 TRD OffRoad - 96 4runner 4x4
    sweet truck bro , I had a friend with one like it . We used to trade vehicles for awhile ( I had a CJ5), that was my first drive in a Toy....been hooked ever since...traded the CJ5 for my 84xtra cab
  5. Feb 13, 2011 at 9:57 PM
    #85
    Ninja14
    Arkansas
    found a pic of my 86 when I first got it....it looked a lot better after some new tires
  6. Feb 13, 2011 at 9:58 PM
    #86
    Ninja14
    Arkansas
    whoops...here it is
  7. Feb 14, 2011 at 1:09 PM
    #87
    drcollie
    drcollie Active Member
    .....and it all fits in the back....
  8. Feb 14, 2011 at 1:25 PM
    #88
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    Here is my '90 that I drove in highschool. I loved this truck so much! I beat the hell out of it and it never failed me.
    This was my '83 crawler. It had Alcan springs and an all-pro flatbed kit. Also 5.29's.
    And my friends '80.
  9. Feb 24, 2011 at 10:29 AM
    #89
    jcemitte
    jcemitte Livin' the taco life
    Jake
    Tulare CA
    04 Taco SR5 5 lugger
    Deck Plate mod, Knock Off Flowmaster,billet grill, alpine HU w/kicker amp and pheonix gold 12" sub stock componets
    well, just goes to show that a tacoma is a good investment. buy it wait a couple years then sell it and buy a house out right....thats what i call resale value :D
  10. Mar 6, 2011 at 9:04 PM
    #90
    big dog
    big dog Hug balls bitch
    Las Vegas
    03 SR5 TRD 4X4
    OME 3" k&n cai magnaflow muffler all pro front bumper 4x innovations rock sliders moto metal wheels with 33" Bridgestone dueler revo 2 AT tires
    my 89 V6[​IMG]
  11. Mar 17, 2011 at 5:38 PM
    #91
    Ninja14
    Arkansas
  12. Mar 17, 2011 at 7:25 PM
    #92
    Sandhopper
    Sandhopper Well-Known Member
    This is a great Thread... Had to go dredge up some old pics of my 1st Toy...
    The Day we brought is home. I was only 15 so the extent of my driving was up and down the driveway. LOL
    Uploaded with ImageShack.us
    Some highschool Mods... Get a load of those light covers :)
    After paint and body work. 8" Rims and 31"x10.5's
  13. Mar 17, 2011 at 8:08 PM
    #93
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Here is my "new" 86 with a 22re 5speed. Needs a new head but it came with all the new parts. will be a summer project after my supra is done.
    wish i still had a pic of my old 86. had the 4 speed auto in it! was hilarious and fun truck
  14. Mar 17, 2011 at 8:29 PM
    #94
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    That's a great project, are you gonna do a build thread here?
    Supra and an 86 22re to compliment it =:drool:
  15. Mar 17, 2011 at 9:15 PM
    #95
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    This is my 2nd Toyota truck. 89 4Runner. Also owned a 84 Xcab pickup, no pics though. :( These were taken before I put the 4 inch Trailmaster lift on it. I sold it last year so I could buy my Tacoma, it had 316,000 miles on it, still had the original motor. I miss it, yet I don't.......
    ^^^The one time every 4 years that it snows in Tucson.....
  16. Mar 17, 2011 at 10:26 PM
    #96
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks man! and yea i guess i could do a build thread! tho it'll end up being my lil bros truck so it'll be up to him to pimp it out. I have a 96 taco to pimp out haha its funny my dad has an 08 taco too. we are a yota family :p
    and the supra is gonna be sick man! heres the gorgeous motor..more has been completed on it since this pick, but you get the idea. its an 87 btw :)
    Arctic Taco likes this.
  17. Mar 18, 2011 at 7:35 PM
    #97
    ToyoTRD
    ToyoTRD Member
    Utah
    N/A
    Nice old looking trucks!
  18. Mar 23, 2011 at 7:41 PM
    #98
    whiteynut
    whiteynut Well-Known Member
    state of confusion
    06 trd sport
  19. Apr 10, 2011 at 11:15 PM
    #99
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    These things are way to clean. We need something dirty... My new blessing... Currently putting it through college
    In high school it received a flat belly, dual Marlin built tcases, square tube front drive shaft, 103" wheelbase, celica seats, 35s
    It's current schooling is dual 5.29 Detroits, dual Rock Assault housings, dirty thirties, 3" lift front, 63" Chevys, extend wheelbase 7-10", 4x Innovations roll cage, 37s, 5 pt harnesses and a couple of other things! :D
  20. Apr 11, 2011 at 7:23 AM
    #100
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    Im telling. Lurking on TW :) JK
    I knew you would post sooner or later
    Here is my 85 in his new home. Currently getting torn down and addressing a few little nuisiance problems
