1980 HydroStream Vamp resto-mod
Discussion in 'Boating & Fishing' started by 5nahalf, Oct 8, 2023.
  1. Sep 21, 2024 at 6:29 PM
    #881
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    New prop is on, went to go do the lower unit oil and its fresh as can be in there, though now I cant get the smell of gear oil out of my nose....
    RustyGreen and thomasburk like this.
  2. Sep 22, 2024 at 12:06 PM
    #882
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    I love the smell of gear oil in the morning! LOL
  3. Sep 22, 2024 at 4:40 PM
    #883
    5nahalf
    Erik
    Minnesota
    52 mph! We are having a fueling issue at higher RPM though, it starts pulling really hard, then it starts to fall down to 45mph as all the fuel in the bowls runs out and the pump cant keep up.
    So Im going to replace the fuel pump and the lower fuel line.
    Also the tilt and trim unit can not lift the motor when its under load, it could easily trim up the 85hp motor under full throttle, but this one has too much power. I really need to get a jack plate and get the factory trim system hooked up so I can trim it out right.
    https://www.youtube.com/watch?v=Wv4K59JOZyk&ab_channel=Downintheparkfishing
  4. Sep 22, 2024 at 6:02 PM
    #884
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    That sounds great when it is pulling hard. :thumbsup:
    How many RPM can that type of engine make?
    5nahalf[QUOTED][OP] likes this.
  5. Sep 22, 2024 at 6:09 PM
    #885
    5nahalf
    Erik
    Minnesota
    5500-5700 rpm at wide open. Tach will be here this week, so I am going to put that in and do another run next weekend after taking care of the fuel issue.
    RustyGreen[QUOTED] likes this.
  6. Oct 2, 2024 at 6:13 PM
    #886
    5nahalf
    Erik
    Minnesota
    Speedometer has now been replaced with a tach. Going to hook it up tomorrow and get the boat out this weekend.
    Got some good suggestions on facebook for my fuel issue, also got some bad suggestions. But the best one I got was that since I am using a sealed fuel tank, pulling that much fuel is creating a vacuum in the tank so it cant flow fast enough into the motor.
    So, I will give it another shot with the fuel cap cracked open a bit. If that does not work, then I will replace the remaining old fuel line, and rebuild the fuel pump.
  7. Oct 14, 2024 at 3:30 PM
    #887
    TwistedTLM4
    TwistedTLM4 Unknown Member
    Philadelphia, PA
    '05 DCSB TRD Sport
    WeatherTech Floor Mats, WeatherTech Bug Shield and Vent Visors, Audio Upgrade, RaamAudio RaamMat & Ensolite, Mr. Marv's Custom 10" Sub Enclosure, Pop N Lock Electronic Tailgate Lock, mattgecko's Bedlights, Demello Offroad Single Hoop Bumper, Marathon Seat Covers, Leer Topper, OME885s on 5100s, @Blackout14 HD Leaf Pack
    My buddy just came into a 140 HP with wiring in same condition.
    Where did you source your wire harnesses?
  8. Oct 14, 2024 at 4:01 PM
    #888
    5nahalf
    Erik
    Minnesota
    This is the harness I got https://www.amazon.com/gp/product/B00AJVNIAY?ie=UTF8
    Make sure it fits that year before ordering though, I think it should, but this harness was 79-81 only I think. Mercury did some goofy things on these motors when they were switching from distributor to ADI systems.
    That motor has the ADI, but its also still got the plug on the side of the motor so its the early model of the ADI.
    The usual suspects in the harnesses on these are the main harness, the stator harness and sometimes the trigger harness.
  9. Nov 13, 2024 at 3:00 PM
    #889
    5nahalf
    Erik
    Minnesota
    Whelp the boat has officially been put to sleep for the winter. I have done the motor prep, unhooked the batteries, and covered the front with ice fishing gear.
    6 more months and I will be back out on the lake with it. While I am waiting for summer to come back, I will be on the hunt for a jack plate to replace my tilt and trim plate.
    koditten, thomasburk and RustyGreen like this.
  10. Nov 13, 2024 at 4:23 PM
    #890
    kent50
    Kent
    A job well done sir. You'll have many years of fun with it I'm sure.
    5nahalf[OP] and RustyGreen like this.
  11. Mar 10, 2025 at 2:33 PM
    #891
    5nahalf
    Erik
    Minnesota
    Spring is in the air and its time to get the boat ready for the summer. First order of business was to get the noco charger all hooked up and mounted. I put it on the transom and hooked it up to both batteries.
    Next up is to buy a new gas tank for the boat, I want one that I can put a external fuel filler neck on so I can fill the boat without having to remove the rear panel/seat
    Before I get the fuel tank though, I need to build the rear seat. The new motor is a little too fast to have the kids just flopping around on the deck. Going to start the rear seat this weekend, going to build it out of 1/2 inch plywood. It will be anchored to the floor in 4 spots and then to the splashwell in 2 spots. Still trying to figure out the best way to anchor it to the floor, Im thinking if I use metal hooks that the cushions can hook to will allow me to remove them easy to get to the mounting bolts for the seat.
    Rezkid, RustyGreen and thomasburk like this.
  12. Mar 10, 2025 at 3:06 PM
    #892
    RustyGreen
    sleeping in a chair
    Pavement Princess
    And we are back at it!!!
    :yes:
    "We" as in you do all the work & your viewers get to enjoy the project.
    thomasburk and 5nahalf[OP] like this.
  13. Apr 1, 2025 at 4:05 PM
    #893
    5nahalf
    Erik
    Minnesota
    After spending time planning out a rear seat, I have found that its going to be cheaper just to buy one.... so I bought one.
    Its not a perfect match to the front seats, but its close enough and it folds down. Its 48 inches, and the boat is 50 inches wide in the back, so it will be nice to fit the full width. It will be here next week sometime where I can start making the mounting solution for it.
    thomasburk, kent50, Rezkid and 2 others like this.
  14. Apr 10, 2025 at 7:04 PM
    #894
    5nahalf
    Erik
    Minnesota
    New seat is here and its perfect! Just need to build the stand offs for it to bolt it down to the floor. It will sit a few inches higher than this picture. I really need to get this boat out of the garage though so I can wash and vacuum it all out.
  15. Apr 12, 2025 at 3:51 PM
    #895
    5nahalf
    Erik
    Minnesota
    Alright, frame is made and the seat is on it. Just need to screw the frame into the floor and we are all set.
    kent50 and RustyGreen like this.
  16. Apr 14, 2025 at 7:37 AM
    #896
    5nahalf
    Erik
    Minnesota
    Carpet all vacuumed up and cleaned, seats match pretty well and now I have a small storage area under the rear seat. I have my tools under there right now.
    Next up is I want to make some side panels to go next to each seat. Im going to build them just like the carpet ones I have on there right now, but they will be just smaller ones that fill in that gap on either side. Im thinking I will make them with some foam and cover them in gray vinyl to match the rear seat and give the kids something softer to bump into.
    I have some more folding cleats that showed up, Im planning on mounting them inside the boat as a dog leash holder. My dog isnt the best swimmer, nor is he the smartest crayon. So he has to be leashed on the boat or he jumps off.
    I have a bimini top on order, it should cover everything from the dash to the splash well to give us some nice shade.
    The wind shield is going to get made hopefully this coming weekend. Debating on tinted plexi vs clear. I like the look of the tinted, but clear would be much better for being able to actually see.
    Rezkid, RustyGreen and Steves104x4 like this.
  17. Apr 15, 2025 at 4:16 PM
    #897
    5nahalf
    Erik
    Minnesota
    Started making the rear seat trim panels, had to order some more clips though before I wrap them in foam and vinyl. These are going to be padded for the kids instead of just carpet like the rest of the panels are. If they come out nice, I may pull the rest of the panels and wrap them too.
    I was also thinking about putting some speakers back there, but decided against it as you cant hear anything over the engine anyways.
    RustyGreen and BEAR_KNIFE_FIGHT like this.
  18. Apr 15, 2025 at 6:05 PM
    #898
    5nahalf
    Erik
    Minnesota
    Little CAD (Cardboard aided design) for my windshield. I did one side, then I will just mirror it for the other side.
    What do you think, clear or tinted? The stock is tinted, and it would look real nice, but I fear it might make a little hard to see out the front very well.
    RustyGreen likes this.
  19. Apr 15, 2025 at 7:29 PM
    #899
    kent50
    Kent
    Tinted would look cool but I think clear is the better choice for overall visibility.
    RustyGreen and 5nahalf[OP] like this.
  20. Apr 15, 2025 at 7:39 PM
    #900
    5nahalf
    Erik
    Minnesota
    For sure on clear being a better choice. Depending on how the first clear one comes out, I might try to make a tinted one too.
    I think I am also going to make a plug that I can form these windshields with. Right now no one makes them, and I can make a plug from layered wood and fiberglass so I can start bending more.
    kent50[QUOTED] and RustyGreen like this.
