1980 HydroStream Vamp resto-mod
Discussion in 'Boating & Fishing' started by 5nahalf, Oct 8, 2023.
  1. Jun 12, 2025 at 7:57 PM
    #941
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    And I finally got around to making the trailer look less like a crack heads stolen bike...
    No more brown and white spray paint with dirty red wheels
    TwistedTLM4, RustyGreen and Rezkid like this.
  2. Jun 13, 2025 at 10:13 AM
    #942
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    Nice!
    5nahalf[OP] likes this.
  3. Jun 21, 2025 at 8:50 PM
    #943
    5nahalf
    Erik
    Minnesota
    Boat ran amazing this week up at the cabin! Started right up each time, but then I ran out of gas about 200 feet from the ramp. Luckily a nice guy that I had been chatting with 5 hours earlier was near by and he came and pulled us to shore.
    https://www.youtube.com/shorts/2_jnUq3k48E
  4. Jun 22, 2025 at 1:24 PM
    #944
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    It is great that all the hard work you did is now paying off with some fun family time. :yes:
    The boat looks fast even on the trailer.
    ( :gossip: with the best color truck BTW - no bias naturally ;) )
    Next upgrade a low fuel light? :laugh:
  5. Jun 22, 2025 at 1:28 PM
    #945
    5nahalf
    Erik
    Minnesota
    Yep, Im looking at a better fuel tank right now. I have a plastic fuel tank in there right now that I had gotten to make sure everything worked right. Im going to have a custom aluminum one made soon. It will have a electric fuel level sensor and a filler nozzle on the outside of the boat so I dont need to flip the seats out of the way to gas up each time.
    Tank thats in there is 12 gallons. I can move up to a 21 gallon tank if I get a custom aluminum one. I might swap out my second 12v lead acid battery for a smaller lithium one. That battery just runs the radio and lights.
    RustyGreen[QUOTED] likes this.
  6. Jul 6, 2025 at 5:37 PM
    #946
    5nahalf
    Erik
    Minnesota
    Found a great deal on a jack plate, hoping to go pick it up tomorrow. Its a 10 inch setback, and thats a ton for my boat, but luckily its 2 parts, so I can remove 5.5 inches of spacer off that and get me to 5.5 inches of setback. This will replace my current tilt and trim plate thats on the boat now, and I will put on the factory mercury system.
    The jack plate should also let me bolt this motor up better than the clamps it currently is using.
    With the jack plate I can actually adjust the height of my motor to get it at the perfect depth. Right now Its a little low in the water, but I cant raise it anymore with the clamp system the motor uses. So I can move the jack plate up a bit, and that will reduce drag on the back end of the boat to get a little higher top speed.
    RustyGreen and kent50 like this.
  7. Jul 7, 2025 at 2:52 PM
    #947
    5nahalf
    Erik
    Minnesota
    Jack plate acquired! I already took off the fixed 5 inch plate and started cleaning up the adjustable jack plate (the part I wanted) Looks like this plate lived in the river on the boat, so its pretty dirty, but its in really good shape. I only had to file down one deformed bit of aluminum, it was a spot from someone using a punch to split the plate from the boat.
    RustyGreen likes this.
  8. Jul 8, 2025 at 2:43 PM
    #948
    5nahalf
    Erik
    Minnesota
    Not ideal, but this should keep the sun off us while putting around. I need to setup a better rear mounting point for the straps, they are wrapped around the cleats.
    kent50 and RustyGreen like this.
  9. Jul 8, 2025 at 4:27 PM
    #949
    5nahalf
    Erik
    Minnesota
    ok, got the rear straps all setup. I mounted them the same as the front straps, there is a padeye mounted to the inside float pods on each side, the straps connect to those and then up to the top. I thought about putting the rear bars in, but that will just block my view if I am pulling the kids on the tube.
    But here is the top stowed, I have a cover for it so it wont turn into a giant parachute on the highway. I do need to strap it down to the hull while underway though.
  10. Jul 16, 2025 at 11:26 AM
    #950
    5nahalf
    Erik
    Minnesota
    Cleaned up the new jack plate, also got the new spreader plates. I originally only had a top spreader plate, now I have both top and bottom. The will help distribute the load over a larger area to keep the bolts from crushing the transom.
  11. Jul 21, 2025 at 2:26 PM
    #951
    5nahalf
    Erik
    Minnesota
    Got the new jack plate installed today, still trying to figure out the best way to mount the motor to it though. I can use the clamp on adapter with some modifications, or I can try to bolt the motor right to the jack plate.
    Here you can see I would need to modify the clamp on adapter a bit as it doesnt fit flat on the jack plate
    But these bolt holes line up pretty great to bolt it on
  12. Jul 21, 2025 at 3:53 PM
    #952
    5nahalf
    Erik
    Minnesota
    Alright this should work. I used part of the clamp on adapter to make a spacer for the clamps, then I will run bolts into the trim ram mounts and the bottom mounts.
  13. Jul 21, 2025 at 7:30 PM
    #953
    5nahalf
    Erik
    Minnesota
    There we go, hydraulic cylinders installed, hoses halfway installed. Tomorrow I will mount the pump and run the lines into the hull and refill the pump with oil.
    I do need to drill out the 2 lower holes for the motor to mount too, those should be pretty easy to take care of though.
    Next thing I need to do is to get a new fuel tank with a fuel level sender so I can hook up my gauge.
    Front sight and RustyGreen like this.
  14. Jul 22, 2025 at 7:20 PM
    #954
    5nahalf
    Erik
    Minnesota
    Welp I have run into a problem, 2 of the hoses are about 5-6 inches too short, the 2 hoses on the opposite side of the boat from the trim pump. I can get them to fit to the pump, but they are super tight and the larger diameter one gets kinked due to the sharp angles.
    I have moved the pump to the left side of the boat now (was on the right side), and will be drilling a new hole in the topside of the boat to run the hoses as the right side of the boat hole already has throttle cable, shift cable, wiring, fuel line, and steering cable, so its a bit too full of things over there.
    Im hoping that having a little more space in the hole combined with moving the pump to the other side will give me a little more slack on the lines. The other option is to get a few 6 inch hard lines and just extend the hoses. Otherwise I can see if a hose shop can cut and splice in a few extra inches to the hoses I have.
    RustyGreen and TwistedTLM4 like this.
  15. Jul 23, 2025 at 7:43 PM
    #955
    5nahalf
    Erik
    Minnesota
    Trim pump all mounted up, new hole drilled for the lines to come through. Eventually I will be putting a new motor on the boat that has a built in trim pump, so this hole will be converted into a fuel filler hole. But for now its for the hydraulic lines.
    TwistedTLM4 and RustyGreen like this.
  16. Jul 28, 2025 at 8:11 AM
    #956
    5nahalf
    Erik
    Minnesota
    4 new hydraulic hoses should be showing up this week (today and tomorrow), they are the same length as the old hoses, but not 40 years old. I could of had 2 custom length ones made, but at $2.89 per inch and needing 72 inches, it was just too damn expensive. Making a extension is going to be way way cheaper.
  17. Jul 29, 2025 at 7:16 PM
    #957
    5nahalf
    Erik
    Minnesota
    Well this sucks... one of the fittings on the trim pump manifold pulled the threads out. So now I have brand new hoses, but the pump manifold is shot, I did find a replacement manifold on ebay, really surprised I found just the manifold too as these are not easy to find in good shape. So the new manifold should be here sometime next week, then I get to take mine apart and put on the new parts.
    I might take the old manifold and see if I can get the threads fixed at a machine shop. But not holding my breath on them being able to fix it or even wanting to fix it.
  18. Jul 29, 2025 at 9:09 PM
    #958
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :annoyed:
    :censored:
    :sorry:
    5nahalf[QUOTED][OP] likes this.
  19. Jul 29, 2025 at 9:25 PM
    #959
    5nahalf
    Erik
    Minnesota
    On the plus side, it did force me to rethink my trim pump mounting location. Even with some extension, putting the pump where I put it caused too much strain on the hoses. The way the hoses are made, they pretty much have to go from the rams, straight forward then loop down to the pump. I cant go to the side as the fittings on the hose do not rotate to fit. Its kind of hard to describe, but the lines can pretty much only go one way and you need to modify the boat to fit them.
    So, I am making a plate that I will mount to the floor of the boat and it will tie into the bottom of the splash well. This will put the trim pump in a good place, To put the pump here, I have to rotate my starting battery, and I will probably need to swap out my aux battery with something smaller. This all should drop the weight a fair amount from the back. Going from the heavy 50lb tilt and trim unit to the lighter weight jack plate and factory trim, and dropping the 50lbs from the aux battery. In all I should be getting rid of around 80lbs from the rear.
    The new location for the pump will actually bring the hoses from the rams straight forward, then between the splashwell front bulkhead and the rear seat. Its not super pretty but for the rest of the summer it should be good. Drilling into the splashwell is not really a option to run the hoses, if I upgrade to a newer motor, those will just be open holes that I dont want.
    I also need to redo my bilge pump a bit too. Its been just kinda flopping around in the back of the boat, time for me to actually mount it to something, maybe route the hose less sloppy.
  20. Jul 30, 2025 at 12:12 PM
    #960
    5nahalf
    Erik
    Minnesota
    New trim pump mounting installed and sealed up. Also rotated the starting battery to clear the pump.
    This is how the hoses are going to run for now, they will just wrap over the back here.
