1980 HydroStream Vamp resto-mod
Discussion in 'Boating & Fishing' started by 5nahalf, Oct 8, 2023.
  1. Aug 24, 2025 at 7:05 PM
    #981
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    Oof That is rough. Hope you figure it out. :thumbsup:
    5nahalf[OP] likes this.
  2. Aug 24, 2025 at 7:08 PM
    #982
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Hope so too, season is coming to a end and I would love to get it out more as the water cools down and the fish start going crazy for food before winter.
  3. Aug 24, 2025 at 7:28 PM
    #983
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    :mad:
    I thought you put in a new fuel tank?
    5nahalf[QUOTED][OP] likes this.
  4. Aug 24, 2025 at 7:33 PM
    #984
    5nahalf
    Erik
    Minnesota
    Pretty much the whole fuel system is new, but I fear that grit and sand is falling off the filler nozzles and my oil cup when I mix. This is then getting sucked up the hose and into the carbs.
    There should be a filter screen inside the fuel pump, but Im thinking that its either missing or has big holes in it. So putting a finer filter on before the pump should help fix that.
    RustyGreen[QUOTED] likes this.
  5. Aug 24, 2025 at 8:34 PM
    #985
    5nahalf
    Erik
    Minnesota
    Just pulled the fuel pump apart, screen is intact, there were a couple larger chunks of stuff in the screen, but I think things are just getting past it.
    RustyGreen likes this.
  6. Aug 25, 2025 at 7:05 AM
    #986
    5nahalf
    Erik
    Minnesota
    ok, so I think I have it figured out. When the last owner rebuilt the fuel pump, they forgot a single O-ring on the fuel pump screen, this is allowing chunks to go around the screen. So im going to install the fuel filter like I planned, but I will rebuild the pump this fall when I do the water pump and lower unit oil.
    I want to do some ignition timing today too, I want to make sure its right, but having the fuel system empty and disconnected is the perfect time to set timing as I dont want the motor to be able to start.
    But I need to pick up a dial indicator and timing light to get it right. The procedure is funny, you need to find TDC with the dial indicator, zero it out, then turn the flywheel until its .467 inches below TDC (TDC is a very large range on these motors, but .467 is only 1 spot) Then from there I can adjust the timing indicator. After the indicator is zeroed, I can put the timing light on it and adjust idle timing, and then WOT timing screws.
    kent50 and RustyGreen like this.
  7. Aug 25, 2025 at 8:37 PM
    #987
    5nahalf
    Erik
    Minnesota
    Got the motor all timed, and fixed up. Have to wait on the fuel filter though, the only ones I could find local were paper element ones, and those dont like 2 stroke oil. So I will have to order one.
    But, after getting it all back together, I spent some time with my old BMW. Its been sitting since 2017 and I would love to take it out this fall. Checked the fluids, cranked it up but no fire. It starts on spray, but the not on its own. So I hooked some leads up to the fuel pump and found its seized due to the old gas evaporating and varnishing over the pump. New pumps on the way so I should hopefully have that car running next week. I might go see if I can get my challenger running this week too, it last ran 2 years ago.
    This picture is from 2017 when I cleaned the convertible and put it in the garage where it has not moved since.
    RustyGreen and Rexfordian13 like this.
