1981 16' Starcraft Seafarer Restore (PIC Heavy)
Discussion in 'Boating & Fishing' started by smitty99, Aug 2, 2017.
  1. Sep 4, 2017 at 5:53 PM
    #41
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    BTW great job on the boat resto.
    Presently building a drift boat myself. No build thread, at least on this site, yet.
    smitty99[OP] likes this.
  2. Sep 4, 2017 at 7:47 PM
    #42
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    That was before it was restored. Those were 30+ year old hubs. There were no nuts on that original hub design.
  3. Sep 4, 2017 at 7:51 PM
    #43
    smitty99
    Scottsdale
    Thank you for the compliments. I am lucky to have nice things.
  4. Sep 4, 2017 at 7:51 PM
    #44
    koditten
    Kirk
    Central Michigan
    Your pictures show the old hubs with lug bolt and then showing the replacement hubs with lug studs and nuts. If you have not turned the lug nuts around so the round part is facing in, they are on the wrong way.
    The post I quoted shows the original hubs. You have to open the whole post to see the new hubs and nuts.
  5. Sep 4, 2017 at 8:13 PM
    #45
    smitty99
    Scottsdale
    Nevermind I got you
  6. Sep 4, 2017 at 8:15 PM
    #46
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I'm here, Captain.
    smitty99[QUOTED][OP] likes this.
  7. Sep 4, 2017 at 8:31 PM
    #47
    BlueHeli
    BlueHeli Well-Known Member
    AZ
    2017 Quicksand TRD OFFROAD 6MT
    None
    That is one sweet restoration thread. I bought a 1982 Mirrocraft Deep Fisherman back in May with a 1972 Dilly trailer. Im looking at restoring it but I just don't have the time right now. This is really encouraging.
  8. Sep 16, 2017 at 5:05 PM
    #48
    ElBlancoTaco
    ElBlancoTaco Well-Known Member
    Ron
    Scottsdale, AZ
    2014 SR5 DCSB 4x4
    Great write up, I miss having property where I can undertake projects.
  9. Jul 11, 2019 at 3:43 PM
    #49
    Rynotows
    Rynotows Member
    Ryno
    2016 Tacoma DC
    Great job. I’m not a boat guy but it was a great read. Very pretty boat.
    I like the Goat too.
  10. Feb 23, 2020 at 12:24 PM
    #50
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    Beautiful restoration work! Mine 10ft for small lakes. About 50 offroad remote fishing trips per year.
  11. Sep 8, 2021 at 10:06 AM
    #51
    atrens
    atrens New Member
    Andrew
    Excellent restoration! :)
    Have read-through and very much appreciate all of the details! Your hard work on this will save me (and I suspect a lot of others) a ton of time! :)
    I have four (hopefully) quick questions. I'm restoring a similar boat - a 1975 seafarer - it has original paint and is in better shape than the boat you started with.
    The first question is the transom .. is that topside paint that you applied? I'm thinking of leaving mine as shiny aluminum as it will be spending most of its time in the water, albeit in a very clean, cold lake with very 'soft' water. Folks are telling me that topside paint won't stand up to being immersed. Not sure what you've learned on the topic and how you came to your decision to paint your transom.
    Second question is etching primer. I don't recall which one that you used, if any. Folks say that it's definitely needed on bare metal. As is 80 grit sand paper.
    Third question is weepy seams. My boat doesn't substantially leak but I am noticing a bit of weeping along the transom bottom seam - over eight hours a couple thimble-fulls of water. Nothing seems loose .. I'm not familiar with how these boats were put together but I suspect some freeze-thaw over the years may have created pathways for moisture along that seam. Someone suggested 'gluvit' which I will try I think. It looks like messy stuff. Any experience with that?
    Finally, last question. Citristrip. I'm hoping to get the back of my transom back to bare, shiny aluminum. What is the easiest way to do that? Thinking that scraping or using something on a rotary tool (or drill) would lead to marks that would be absolutely miserable to polish-out. And that that old paint is probably high in zinc chromate and who-knows-what-else. Would like to avoid chemical burns and ending up in a cancer ward in a dozen years if at all possible. :) Thank goodness it's a small boat! :)
  12. Sep 11, 2021 at 4:13 AM
    #52
    atrens
    atrens New Member
    Andrew
    Gluvit was a piece of cake. Super easy to apply.
    Used an eco-stripper similar to citristrip on the transom. Took about an hour and a half. Also easy. Wore nitrile gloves and avoided touching anything. No sanding. A bit of puddling of stripper on the shop floor.
    Occurred to me that in 1975 starcraft paint might still contain lead. Will assume that and test that today. No dust yet but will contain the puddles and all of the rags.
    Had hoped to strip the bottom part of the hull back to bare metal but depending on lead result may leave as is.
  13. Sep 12, 2021 at 6:04 AM
    #53
    atrens
    atrens New Member
    Andrew
    No lead. That’s good news.
    Almost certainly zinc chromate primer - aluminum under the paint looks showroom-new, so still warrants care/caution and no sanding. Found a moeller zinc phosphate primer spay bomb - going to use that to cover spots where the paint has worn.
    So far have gone through about a quart of stripper - I’m thinking one more quart will finish the job.
  14. Sep 19, 2021 at 5:46 AM
    #54
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Nice job! I just picked up an old 10' aluminum starcraft boat from the early 60's from an estate sale...i'm in the process of having to do the same job as far as replacing the seats, and transom......no trailer though.
