1983 toyota trailblazer
Discussion in 'Off-Topic Discussion' started by gearhead06, Aug 29, 2010.
  1. Aug 29, 2010 at 3:58 PM
    gearhead06
    gearhead06 [OP] Active Member
    josh
    columbus
    07 Tacoma v6 4x4
    I have a 3" lift from suspensionconnection.com... I have 4.88 gears Front and Rear with 2 Arb Lockers.. Im running on some 315/75R16 FIERCE ATTITUDE M/T...
    so im getting an 1983 toyota trailblazer
    22r
    solid front axle
    all the interior room you will ever need
    it is a 1983 so it has its little querks but is a solid truck no rust
    clicking sound from clutch but operates fine...
    so does anyone know anything about these trucks or maybe know why there is a clicking sound coming from the clutch???
    i want to get it so i can take it easy on my 2007 tacoma i have some work to it but parts are not cheap
    i had to replace a u-joint a carrier bearing and i still need to replace inner and outer tie rods i have a 3" lift on it with some 32's and now im getting a noises from the rear sounds like its coming from my diff so i want to fix all that and STOP trail riding it and trail ride the 83 but i dont want to get a P.O.S. if you know what i mean....
    so if anyone knows anything about the 1983 toyota trailblazer let me know PLZ....
    Thanks
  2. Aug 29, 2010 at 5:09 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    hmm...i've seen trekkers, but never a trailblazer....sweet
  3. Aug 29, 2010 at 5:11 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    isnt trailblazer a chevy?
  4. Aug 29, 2010 at 5:12 PM
    jhodge83
    SC
    17 XLT Sport
  5. Aug 29, 2010 at 5:20 PM
    joes06tacoma
    Joe
    Central Coast, CA
    My dad had an 81 Trekker back in the day. Those were very similar, they were fiberglass from the back of the pickup cab all the way to the rear bumper. Is the Trailblazer fiberglass or steel? Other than the bodywork, the Trekker was just a 4x4 pickup. I'm pretty sure you can use all the same aftermarket parts on it that you would for a pickup of the same year. The only issue I can remember with the Trekker was getting new bumper brackets for the rear bumper after it got hit. They were different than a pickup and I believe dad had to get them custom made. I think they are super cool trucks, very slow I am sure, but it's a trail rig!
