1984 tacoma 22r surging
Discussion in '4 Cylinder' started by johnnyjack1, Jul 5, 2011.
  1. Jul 5, 2011 at 5:45 PM
    johnnyjack1
    johnnyjack1 [OP] New Member
    jack
    los angeles
    99 4x4 xcab tacoma
    Hi everybody, I am new here, on vacation using an android device ( viewsonic 10 inch ) and cant use search on it. Don't know why. So if this posted, sorry I cant search. The truck surges at any speed and every grear. So, if I am in second, holding speed at 15mph, the truck speed will drop and speed back up about every second or second and a half. There is also a loss of power at any speed, ( not good in a 4 banger ) I am looking for a vacuum leak now but I don't really think that is the cause. I am thinking it is a carb problem. Any help by you guys would help. Thanks
  2. Jul 6, 2011 at 7:21 AM
    petyanca
    petyanca Well-Known Member
    bay area
    09 AC 4cyl 4x4 5spd
    I doubt there is a carburetor, rather fuel injector, and I would use a bottle of injector cleaner in your next tank and see if it solves it.
  3. Jul 6, 2011 at 8:11 AM
    johnnyjack1
    jack
    los angeles
    99 4x4 xcab tacoma
    Hi Petyanca, it does have a carb. And I put carb cleaner in the tant and used carb cleaner on the carb. I cant find any vacuum leaks.
  4. Jul 6, 2011 at 8:17 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    efi came in toyotas in 85 iirc, as mentions check for vac leaks, then check to see if anything is restrictin air fuel or spark
  5. Jul 6, 2011 at 8:26 AM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    Check the egr mske sure it holds vacum.
    Probabaly doesnt have a TPS does it? That is a common problem on the 22RE
  6. Jul 6, 2011 at 4:57 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Also check for leaks in the intake system (intake manifold/intake tube/etc)
  7. Jul 7, 2011 at 7:59 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Could be the rubber diaphragm in the carb.
    They dry rot and will not keep proper pressure...so the engine
    will run rough.
    Buy a carb rebuild kit and the rubber diaphragm is included...
    pretty easy to replace.
    Good luck.
  8. Jul 7, 2011 at 9:21 AM
    petyanca
    bay area
    09 AC 4cyl 4x4 5spd
    oops sorry I thought you were talking about truck in your profile.
    Yeah i think a rebuild kit should help, and may be clean all the passages with carb cleaner.
  9. Jul 12, 2011 at 5:36 PM
    johnnyjack1
    jack
    los angeles
    99 4x4 xcab tacoma
    Thanks guys, I am in the Oregon hills and don't have internet. I found a leak under the carb, so i made a gasket and it runs somewhat better. The serge now is fast just like if you were tapping the gas petal, but only under a slow load. I think I will rebuild the carb next. Thanks again.
