1989 toyota pickup 3.0l V6 no power??????
Discussion in 'Toyota Trucks & SUVs' started by mac424205, Apr 9, 2012.
  1. Jun 18, 2012 at 1:04 PM
    trmarshall1
    trmarshall1 The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
    Congratulations on getting her up and running man! I literally roflmao when I read your last post and saw, "afro engineered out the yin yang", classic bro. Can't wait to start perusing your build thread.
  2. Jun 18, 2012 at 3:05 PM
    mac424205
    mac424205 [OP] Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    lol I might start this as the build thread! lol. Pretty much everything that has been done to it is in here.
  3. Jun 18, 2012 at 3:27 PM
    0psi
    0psi Well-Known Member
    Tommy
    Westminster/glen burnie Maryland
    Color match handles,sport hood,fx-r retrofit,fog light any time,eclipse avn726e
    If you want to do a 3.4 hit me up I can help with any question you have.I did it to my 4runner with supercharger.
  4. Jun 18, 2012 at 3:36 PM
    detnight
    detnight Well-Known Member
    David
    Texas City ,Texas
    Texas Edtion Sport Super White
    Bed cover, Borla exhaust,20in wheels The TEXAS edition
    I have a 89 extra cab(3/4 ton) with the 3.0 AT. It has about 190,000 on it and it gets 26mpg HWY and 22mpg in town. Before I got my 09 Taco it was used to pull my Harley in a 10ft Cargo trailer. I have never had any problems with the truck.
  5. Jun 18, 2012 at 8:54 PM
    mac424205
    Mathew
    Chelsea
    I appreciate it guys. This is going to be a fun project for me. It will be my FIRST project also.
    With that being said, I am up to any info and comments.... I know what motor I got so I don't need a 3.slow comment. I am 22yrs old, have a family, and on a budget. I pay for EVERYTHING my self and don't ask for help.
    0psi, when I do the swap, I will keep you in mind. unless you wanna go ahead and just sell me your runner! lol jk
    detnight. Idk what kinda mileage this thing will get. I have had it for several months and just put 100 miles on it! lol Those miles are from driving it everytime I replaced something!
  6. Jun 18, 2012 at 8:56 PM
    joes06tacoma
    Joe
    Central Coast, CA
    The 3.0 came out in 1988. I read somewhere that the first couple years of production had asbestos headgaskets, and that the problems started when that product was legislated out of the gaskets. If I am not mistaken, the whole "service campaign" that Toyota had on the 3.0 didn't apply to all years.
  7. Jun 18, 2012 at 9:12 PM
    mac424205
    Mathew
    Chelsea
    Sorry about the picture. What do ya'll think about flat bed?
  8. Jun 20, 2012 at 10:18 AM
    ravenlord
    ravenlord Well-Known Member
    Scott
    Nova Scotia
    Flat bed her up man. Flatbed 5th gen pickups are mint.
    If you plan on keeping the 3.Slow for any length of time then I would suggest doing the head gasket before she blows, put some ARP head studs in there, and rebuild the criminal crossover pipe. Block off the DVR side manifold and build a "Y" pipe so that the cylinder banks are dumping into seperate outlets. Bit of work, but way cheaper then going the 3.4 route.
    I don't exactly like the power that the 3VZ-E produces, but they are actually a fairly good engine when running right. They have excellent trail manors, and will roast tires if you gear them right... :D The 4.56 rear end will be your best friend. My only real gripes are the crossover pipe dumping #5 cylinder gases right at the #6 cylinder as #6 is on its exhaust stroke. That is what kill the head gasket.
    If you can drive stick then I would consider putting the R150F transmission and VF1A Tcase into your truck instead of the A340H which uses an integrated Tcase. Or if you wanted to keep it auto you can use a AW4 jeep transmission, swap the bellhousing and then you have the option of using an external Tcase. (the A340 and AW4 are the same internally)
    If you want to go the 5VZ-FE route then remember, if done right it will cost you at least 3000. Getting someone else to do it will cost signifigently more.
    Other then that I am sure you will enjoy many years of faithful service from you '89. I really wish that my '94 wasn't so bloody rotten. However, yotatech.com and will be your best friends from now on out.
  9. Jun 20, 2012 at 7:25 PM
    mac424205
    Mathew
    Chelsea
    The head was actually rebuilt less than 15k miles ago. I hope I am good on that for a good bit. I can drive a stick, that's what my DD is. What would be the cost for swapping it over to a 5spd? What would be the cost for doing what is in bold? If i do swap to a 5spd can I keep the current Tcase and save for a different one or would it be better to go ahead and replace the Tcase as well? Can I get a standard transmission from a 1st gen Taco?
  10. Jun 21, 2012 at 12:13 AM
    ravenlord
    Scott
    Nova Scotia
    The transmission you are looking for is a R150F transmission. The output shaft on the Tacoma is slightly longer then the transmission in the 5th Gen pickups. The other main difference is the transfer case on the Tacoma is a DVR side drop, and the 5th gen is a PASS side drop. You will not be able to use the transfer case in on the automatic truck. The auto transmission is intergrated with the transfer case, the R150F transmission and the VF1A transfer case are seperate units. You should be able to find the transmission and transfer case for around 5-900 depending on mileage and condition. Pedal, master and slave cylinders, flywheel, clutch and anything misc stuff I can't think of right now will run you around 1000 for new stuff. Clutch alone is going to cost 300 minimum. If you offroad a lot it will be worth the money to swap it. If you don't it's pretty much a nil point.
    As for building a Y pipe, it depends on your welding skills. The DVR side manifold has 2 ports. One port is the exit for both cylinder banks and the other port is the port that dumps the exhaust down towards the cat ect. You need to cut the crossover pipe, and angle the pipe to be dumping exhaust down towards the pipe and not into the manifold. Then you need to block off the crossover pipe port on the manifold. Then you need to build a Y pipe that will connect to the crossover and the stock manifold. If you can weld it will take a few hours, some prefab exhaust kits, cutting discs ect. If you cannot weld then its going to cost a fair amount of money to get a shop to modify the truck for you.
  11. Jun 21, 2012 at 7:30 AM
    mac424205
    Mathew
    Chelsea
    I can weld, certified in stick and mig, that wouldn't be the problem. I guess I will have to get someone to show me what YOU are talking about when, and if I get ready to do it.
    I am thinking about selling it and my DD to get an 01 Runner... Not sure though
  12. Jul 10, 2012 at 6:10 PM
    mac424205
    Mathew
    Chelsea
    Got some new pictures. I got bored after I got done with washing cars so I did some flexing and did a poser shot!:woot:
    [​IMG].
    I have more, but no need to post em here. They are basically the same shots but at a different spot. All of these were taken in the vacant lots in my subdivision! lol :laughing:!
  13. Jul 13, 2012 at 11:32 PM
    jessejames3
    jessejames3 New Member
    hey bud just went threw the same problem you may not beleive but check your timing it is a quick check and my help fixed my prblem my timing was 30* btdc
  14. Jul 13, 2012 at 11:34 PM
    jessejames3
    never mind i see you pulled it oh well i tried stupid dail up just finsihed loading post
  15. Jul 14, 2012 at 2:56 PM
    #35
    mac424205
    Mathew
    Chelsea
    Yea, it had to be changed when I bought it so that was the first thing that was done.
  16. Jul 14, 2012 at 3:54 PM
    #36
    cjasu
    cjasu TW resident Camel
    CJ
    Buies creek NC/seminole county
    06 prerunner soon to be moded
    camo seat covers
    So in you guys opinion would you stay away from an 89 yota single cab 5 speed manual ?
  17. Jul 14, 2012 at 10:08 PM
    #37
    mac424205
    Mathew
    Chelsea
    If you want a play toy and project truck, then no! I have enjoyed working on mine A LOT! I would have prefered a 5 spd over my auto, but couldnt beat the price that I paid for it. Make sure that the head gaskets have been replaced recently. If not, that would be the first thing that I would do. IF you got the 3.0l.
  18. Jul 14, 2012 at 10:16 PM
    #38
    cjasu
    CJ
    camo seat covers
    Thanks and that woukd be the plan the add says v6 1989 toyota 4x4 so ill have to ask the guy
  19. Jul 23, 2012 at 9:55 PM
    #39
    mac424205
    Mathew
    Chelsea
  20. Jul 20, 2013 at 8:12 PM
    #40
    02 TRD Tacoma
    02 TRD Tacoma Well-Known Member
    Nathan
    Lenoir NC
    02 Tacoma DC TRD
    Bilstein 5100 front and rear, dakar leaf pack, fuel hostage wheels, 285/70/17 Trail Grapplers M/T, color match shell, rola rack, hi -lift, dual cb antenna's with 520 XL cb, sandblasted bumpers an brush guard to paint black, color match grill, blacked out badges, and much more.
    sweet truck man. from the pics thats a clean 89. cant wait to see the progression. ill get some pics up on the cb bracket. i got it like that at a local cb shop. by the way thanks for the comments on the truck i appreciate it man.
