1990 Tacoma v6 project
Discussion in 'Canada' started by GETLIFTEDCOMA, Feb 27, 2012.
  1. Feb 27, 2012 at 6:14 PM
    GETLIFTEDCOMA
    GETLIFTEDCOMA [OP] New Member
    Jay
    Calgary Alberta
    Tacoma v6 3l
    I have 1990 Toyota Tacoma v6 3l its all stock i wanna lift it and put some compatible tires that will work for gears i don't know where to start i know i need a new front axle to much going on under the stock one. Can any one help with any suggestions cheers J
  2. Feb 27, 2012 at 6:17 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Do you have any pics? Im a little confused because the tacoma started in 1995.5 Just want to see if we are talking about a tacoma here or a pickup
  3. Feb 27, 2012 at 6:32 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    If you indeed have a 1990 you have a Toyota Pickup Truck
    3.0 Litre 150 HP and 180 TQ
    Automatic Transmission A340H, not sure what trans for a Stick.
    Transfer case is a VF1A (H4=?? L4=2.57)
    Gears in Auto 4.10
  4. Feb 28, 2012 at 12:24 PM
    GETLIFTEDCOMA
    Jay
    Calgary Alberta
    Tacoma v6 3l
    Yes you right just found out when had inspection done
  5. Feb 28, 2012 at 12:35 PM
    H Bomb
    H Bomb Well-Known Member
    SAS'd 92 Pickup/08 SR5 Tacoma
    I have a 4 in drop bracket lift on the front and about 6 in lift in the rear. I'm running 33 inch tires with it and it looks fine and drives well. There aren't many great lift options, unfortunately, if you want to keep it ifs. I went with rough country which I wouldn't recommend to others. Also, when you lift it, remember that it is a 20 plus year old truck...so budget for replacement suspension parts like ball joints and tie rods.
