1993 MR2 2GR swap
Discussion in 'Other Builds' started by Empty_Lord, May 10, 2022.
  1. May 18, 2022 at 7:01 PM
    Empty_Lord
    Empty_Lord [OP] Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    second head on, cam towers sealed and installed. its starting to look like an engine again [​IMG]
  2. May 18, 2022 at 7:09 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Have you lapped Toyota valves before and had them last? I thought you’re supposed to just replace them, lapping makes them too thin and they’ll burn up?
  3. May 19, 2022 at 5:14 AM
    Empty_Lord
    Dan
    They’re fine to lightly lap. Your not taking much material off.
    if they had enough pitting for me to worry about it I wouldn’t lap them, but replace. These weren’t bad. But yea. Any engine I rebuild at work gets the valves lapped if it needs it. Rarely intake, mostly only exhaust, like this one
    tinker_troy and RustyGreen like this.
  4. May 19, 2022 at 6:19 PM
    Empty_Lord
    Dan
    a/c compressor, alternator, and fuel pump ordered and coming.
    this cars a mess of parts. its a 2009 4runner a/c compressor, a 2006 avalon alternator, and a 1993 supra turbo fuel pump.
    all being ran by a 2015 sienna ECU with a engine out of a rav4 and pistons from a hybrid highlander.
    to top it off the transmission will be pieced together from 2 e153 mr2 transmissions and a camry/solara e153 for the better final gear
  5. May 23, 2022 at 5:28 PM
    Empty_Lord
    Dan
    Goodies came in. Also engines more assembled. Lack of free time at work has slowed the engine build but it’s coming together. Time allowing tomorrow I’ll be putting the sub pan on and all the other bits and bobs. Need to tack in the Wilhelm oil pan baffle before the lower pan goes on.
    [​IMG] [​IMG]
  6. May 24, 2022 at 7:00 PM
    Empty_Lord
    Dan
    More progress on the engine. Pretty much assembled. Also ordered a new transmission from Toyota. I give up trying to deal with these junkyards for a used transmission. I’ll still piece an e153 together. But fuck it, brand new LSD e153 coming from Toyota. Hopefully soon. I’ll know shortly.
    [​IMG] [​IMG] [​IMG]
    MarX, Superdave1.0, jubei and 4 others like this.
  7. May 25, 2022 at 5:12 PM
    Empty_Lord
    Dan
    Other than the oil pressure sensor and the 2 rear cam sensors, the engine is fully assembled.
    [​IMG] [​IMG]
    MarX, jubei, Rezkid and 1 other person like this.
  8. May 26, 2022 at 10:23 PM
    Empty_Lord
    Dan
    transmission ETA is june 24th according to toyota. fingers crossed it shows up sooner.. need to remove the front half of one of the ones i have to take it and use as a template for the cutting i need to do on the engine block. test fitting starters too. If i can get a chance i'll bench fire the engine at some point
    RustyGreen likes this.
  9. Jun 8, 2022 at 9:19 PM
    Empty_Lord
    Dan
    slowly been working on it at my buddies shop. gas tank out. (need to clean out the mess and paint the outside), rear bumper was rattle canned and looks 10x better. need to fix the front bumper and get it painted with the hood and fenders too.
    [​IMG] [​IMG]
    engine is also fully clearanced (aka the cuts have been done to make the transmission fit)
    got a leak at a heater. will be cutting, flaring, and installing silicon 45 degree hose to fix. this is a common area to crack and this is one of the proven fixes.
    also repaired the blown out brake line with some scrap OEM 2nd gen tacoma line. caliper rebuilds next.
    [​IMG][​IMG]
    MarX, jubei, RustyGreen and 1 other person like this.
  10. Jun 12, 2022 at 8:58 PM
    Empty_Lord
    Dan
    2015 sienna engine harness is fully modified to run the car now (it was previously modified.. i just removed the automatic connectors.) no more automatic related bullshit, ECU will be permanently in drive through jumping 2 wires. (changes the throttle mapping to make it more normal feeling) also repaired a damaged set of fuel injector wires.
    only thing to do after all this is cut off the rear oxygen connector under the a/c compressor and cap the wires off. entire deloom would be needed for that. sooo we'll cheat on those 4 wires
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  11. Jun 13, 2022 at 8:35 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Images broken? Not sure since I'm at work but your older post images are showing for me, just not these last 3 posts.
    MarX likes this.
  12. Jun 13, 2022 at 9:43 AM
    Empty_Lord
    Dan
    It’s from discord. So yes probably blocked. I’ve noticed some people say the older ones pop up. No clue why
    MarX and xtremewlr[QUOTED] like this.
  13. Jun 14, 2022 at 6:58 PM
    Empty_Lord
    Dan
    Removed 3 more connectors. And cut up some other Toyota harness brackets to make the oil pressure wire tuck up nicely and away from the belt. I think it came out pretty factory looking
    MarX, Coma 13, RustyGreen and 3 others like this.
  14. Jun 29, 2022 at 10:07 PM
    Empty_Lord
    Dan
    fuel pump bracket came in... supra turbo pump mounted, all its back in the tank. hope to toss the tank back in after i get the 1/4" bleed line ran for the expansion tank which came in
    [​IMG] [​IMG]
    transmission is still MIA. hopefully soon. i really want to hear this sucker run
    MarX, jubei, Breakfast Taco and 3 others like this.
  15. Aug 10, 2022 at 6:35 PM
    #35
    Empty_Lord
    Dan
    Got one transmission. Home. Tear down tomorrow work allowing. Hopefully figure out I can make one good one from the 2 bad I have. This has been the biggest holdup. trying to find and e153
  16. Aug 22, 2022 at 10:45 PM
    #36
    Empty_Lord
    Dan
    Got a functional transmission! Marc helped toss together a good one from my 2 bad ones. Surprised to find a KAAZ 1.5 way LSD in the complete one. Between those 2 and parts Marc has laying around I’ve got a mr2 transmission with late model syncros, a kaaz LSD, and since it’s all we could find, a slightly shorter 5th gear.[​IMG]
    MarX, xtremewlr, RustyGreen and 6 others like this.
  17. Aug 24, 2022 at 5:49 PM
    #37
    Empty_Lord
    Dan
    Engine and transmission have been married
    MarX, Coma 13, Breakfast Taco and 5 others like this.
  18. Aug 24, 2022 at 7:46 PM
    #38
    strider98
    strider98 Rather Large Member
    2018 Taco DCSB SR5 V6
    bupkis
    Mazel tov!
  19. Aug 24, 2022 at 8:32 PM
    #39
    Empty_Lord
    Dan
    If I can get it lined up I plan to have a running car Monday
    MarX, Breakfast Taco and RustyGreen like this.
  20. Aug 30, 2022 at 8:10 AM
    #40
    Empty_Lord
    Dan
    Engines in. No run… I didn’t change a gasket on the engine and it’s leaking from priming the engine. DOH. Wednesday it should run.
    [​IMG] [​IMG]
    MarX, jubei and RustyGreen like this.
