1994 pickup
Discussion in 'Toyota Trucks & SUVs' started by VW fanboy, Jul 23, 2015.
  1. Jul 23, 2015 at 3:25 AM
    VW fanboy
    VW fanboy [OP] Active Member
    Brandon
    Wausau, Wisconsin
    1994 toyota pickup 4wd DLX extended cab and 2012 VW Passat TDI SE
    Going to be doing a TDI swaperoo
    My truck has 22re with W56E..
    Is it ok to install a R150F transmission still keeping 4x4 capability?
  2. Jul 23, 2015 at 3:33 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    i believe the trans will work but the bell housing WILL NOT bolt to the 22re block.
  3. Jul 23, 2015 at 10:55 PM
    VW fanboy
    Brandon
    Wausau, Wisconsin
    i could care less about it mounting to the block.. im doing an engine swap....
