1995 outside door handle
Discussion in '1st Gen. Tacomas (1995-2004)' started by mkhenson, Apr 10, 2013.
  1. Apr 10, 2013 at 1:11 PM
    mkhenson
    mkhenson [OP] Member
    Arkansas
    1995 Tacoma
    I have had the outside chrome door handle replaced twice on my 95 taco. Seems like i am having to lift the handle so far, that the handle is actually cracking. There must be an adjustment somewhere. Is this something that someone could walk me thru? I'm not even sure about how to remove the door panel. (assuming that needs to be done) Thanks for any help you can give.....MH
  2. Apr 10, 2013 at 4:00 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    Seems like you got some issue with the linkage inside the door.
    Removing the door panel is easy.
    Off the top of my head, remove the two screws in the arm rest/pull. Pop off the trim panel around the switches (if you have any), then remove the wire clips. Remove the little screw in from the interior door handle. Remove door handle from rod.
    Then there's like 6 or so clips behind the panel that you just slowly/carefully pry. Lift up and off to remove the panel.
  3. Apr 11, 2013 at 12:59 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    Actually you need to re align the actual door. When. Rebuilt my truck I noticed I was doing that to the point my handle was about to crack. Turns out I was having to literally lift the door up out of the latch.
    Readjusted and is fine.
  4. Apr 11, 2013 at 1:08 AM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma TRD Offroad sr5
    3" fabtech fox front, 2.5" DAKAR/Bilstein 5100 rear
    Im having this problem as well!
  5. Apr 11, 2013 at 1:09 AM
    brettb
    Brett
    Laramie, Wyoming
    How Did you readjust the door?
  6. Apr 11, 2013 at 1:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    just loosen the 4 bolts. 2 for each hinge.
    you have to remove the fender though too..
    then you can just lift up on the rear of the door and bolt it back down. Takes 2 people really..And be sure not to get it super outa wack.
