1995 Tacoma 3.0 low power
Discussion in '1st Gen. Tacomas (1995-2004)' started by scottmo, Sep 28, 2009.
  1. Sep 28, 2009 at 1:16 PM
    scottmo
    scottmo [OP] Member
    corpus christi texas
    1995 tacoma v6 35x12.50
    5.29 crawlers locker in front 5 inch super lift
    Truck has 35x12.50 tires 5.29 crawlers front and rear. Locker in front runns great at idel and mid-range highway speed 5th gear maybe 60 to 62 at best not missing or back frieing. New cap and roter and fuel filter. any idea on were to look next thanks.
  2. Sep 28, 2009 at 1:36 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    head gasket???
  3. Sep 28, 2009 at 1:43 PM
    scottmo
    scottmo [OP] Member
    Haven't had to add any water and isn't getting hot??????????????
  4. Sep 28, 2009 at 2:09 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Mileage on the truck?
  5. Sep 28, 2009 at 2:27 PM
    scottmo
    scottmo [OP] Member
    98000
  6. Sep 28, 2009 at 2:42 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  7. Sep 28, 2009 at 3:06 PM
    scottmo
    scottmo [OP] Member
    Haven't changed plugs in a while could this cause low power????????????
  8. Sep 28, 2009 at 3:40 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It is a good starting point and easy to to do. It is possible. Here is a good chart on how to "read" your plugs. Make sure the new ones are properly gapped.
  9. Sep 28, 2009 at 7:29 PM
    blkcoma32
    blkcoma32 Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    its ran fine until now? how long have u had it?
  10. Sep 29, 2009 at 8:26 AM
    scottmo
    scottmo [OP] Member
    About 6 months will the large tires and larger gear have that much effect?????????
  11. Sep 29, 2009 at 9:49 AM
    blkcoma32
    Illinois
    it just happened since u put the tires on and gears in?
  12. Sep 29, 2009 at 12:41 PM
    scottmo
    scottmo [OP] Member
    Before it wasn't as sluggish as it is now when you go from first gear to second you have to work the gas peddle it acts like it doesn't want to go kinda hesitata haven"t changed plugs or cleaned throttle body yet hope that is the problem and mayby clean the injectors?????????
  13. Sep 29, 2009 at 2:20 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Well these tires will suck the power out of a motor that was lacking power to start with..
    You may want to research a way to adjust the Clock spring on the Air box.
    Then adjust the gap in plugs. Add a hotter coil pack and make sure all the grounds are clean and the battery is strong.
    When I worked at the dealer and saw a few hunder of these get rebuilt do to head gasket campain we sent a few out for porting polishing.
    THese motors neve did much even when you did do everything right.
    But 20 HP can befound with adding a hotter spark and better air flow and headers...
    But you need to research this. It is not legal in all states.
  14. Sep 29, 2009 at 6:13 PM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    35" tires..?? Uh, yeah.
  15. Sep 30, 2009 at 5:54 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yeah really dude if all this happened when you re-geared and put on 35" tires, then that is your problem
  16. Sep 30, 2009 at 6:01 AM
    scottmo
    scottmo [OP] Member
    Thanks for the info I will try the air box and coil pack idea. Thanks
  17. Sep 30, 2009 at 6:01 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    Ok the 5.29s will spin those 35's without a problem. My 89 had a 3.0 5.29's and 35's and no problems and still had ok power even with a dead cylinder. A 3.0 will never win races and was underpowered from the factory.
    No mater what you do to it to get power it will still suck.
    I bet your HG's are failing. Check your oil!! If the oil is ok run seafoam through it. Also clean your airfilter, change your fuel filter. If you get really crazy put a leak down tester on the engine.
  18. Sep 30, 2009 at 8:51 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    These 3.slow engines are notorious for being under powered. BTW, you have a Hilux, not a Tacoma.
