1995 tacoma 4x4 low power issues help!!!!!!!!!
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by offroader03, Mar 18, 2013.
  1. Mar 18, 2013 at 7:02 PM
    offroader03
    offroader03 [OP] Member
    Chase
    georgia
    95 taco 4x4
    truck is stock for the most part. hot cams from comp cams, aftermarket locking hubs, tool box, hids, jvc head unit, two spl 10s, kicker power cap, kicker 1000w amp, 500w mids and high amp, kicker door speakers, kicker equalizer, 3 inch body lift, 4 inch progressive rate pro comp leaf springs, rs 9000 rear shocks, 4 inch coil overs in front with bilstein 5100 series adjustable shocks, 33 inch be mud terrain km2s, fornt light bar with kc hid offroad lights. cat back exhaust.
    my Tacoma is having issues. when you drive up the road and get the engine loaded it has low power. when you accelerate it lags and when you press the throttle past 50% or so the power kicks in you can actually feel it kick in and start picking up. cleaned mass air flow air filter good. no vacuum leaks or check engine light. hoping someone knows whats going on or has had this problem before. the truck has 287k on it. 2.7l lifted 7 inchs on bf mud tires 33s. hope some one can help thanks
  2. Mar 18, 2013 at 7:05 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Just a guess...Throttle Position Sensor. Also check EGR valve isn't stuck open or closed
  3. Mar 18, 2013 at 7:06 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    02 4runner 04 solara
    4runner-32x11.5x15 falken rocky mt, tundra king 2.5 coilovers with taco perch, TC UCA, OME rear springs and procomp es9000's, thule roof rack.
    1. wrong section, youre in the for sale/ marketplace
    2. maybe a head gasket?
  4. Mar 18, 2013 at 7:14 PM
    offroader03
    Chase
    georgia
    95 taco 4x4
    yeah just figured that out thanks man
  5. Mar 18, 2013 at 7:15 PM
    offroader03
    Chase
    georgia
    95 taco 4x4
    yeah very possible thanks will do
  6. Mar 18, 2013 at 11:56 PM
    yote69301
    yote69301 Well-Known Member
    Nebraska
    95 Tacoma
    Ignition coil
  7. Mar 19, 2013 at 2:21 PM
    offroader03
    Chase
    georgia
    95 taco 4x4
    guessing you had this problem. thanks for the info
  8. Mar 19, 2013 at 2:21 PM
    offroader03
    Chase
    georgia
    95 taco 4x4
    no not at the moment.
