1995 Tacoma Cruise Control
Discussion in 'Technical Chat' started by Pat Masac, Sep 20, 2010.
  1. Sep 20, 2010 at 11:52 AM
    Pat Masac
    Pat Masac [OP] Member
    Patrick
    Beaumont, TX
    Tacoma V6 2WD
    I have a '95 Toyota Extended cab V6 automatic with 291,000 miles on it. Besides changing timing belts, a lower ball joint and fluids, it's pretty much the same as the day I bought it. However, the other day I tried to set my cruise control and it wouldn't work. The cruise control light comes on but it will not engage. I also noticed that my display light on my shift indicator quit working. Realizing that these things happened simultaneously, I assumed it was a fuse. Referring to the shop manual, I check all the fuses that could possibly have anything to do with it and they were all fine. One of the larger fuses under the hood labeled "ALT" I just checked visually without removing it and it appeared to be fine.
    Anyone out there have any idea what I need to do to fix this problem? Thanks for the great board.
    Pat
  2. Apr 10, 2011 at 10:54 AM
    rballnut17
    rballnut17 New Member
    95 Tacoma LX V6 4x4
    Did you fix this issue? I am having the same issue with my cruise control.
    Thanks
